Javelin Stamp Interface to INSTEON and X10
I've started working on a class to interface the Javelin Stamp to the INSTEON PowerLinc
controller, which allows control of INSTEON and X10 devices such as lamp dimmers.
What I've created so far allows control of X10 devices and·monitors for raw X10 codes
received. I'm planning on adding more functionality including INSTEON control capabilities.
The current·source code and links to INSTEON controller information·is at:
http://www.cls01.com/insteon/
Let me know if you find any bugs and/or have ideas for additional functionality.
Following FYI is the output from a·test program that uses the Insteon class:
Scott
Post Edited (Scott/Chicago) : 4/23/2006 8:32:01 PM GMT
Scott
Can you add javadocs to the methods
that also specifies possible return values?
·* Function description
·* @param
·* @param
·* @return
That makes it easier to understand why particular values are returned
without looking it up in the device datasheet.
Could you move the package to stamp.peripheral.x10.insteon
There are more x10 controllers. That way all x10 controllers
can be located in a single location for better overview.
regards peter
Post Edited (Peter Verkaik) : 3/27/2006 5:38:37 AM GMT
http://www.insteon.net/pdf/insteondetails.pdf
regards peter
Thanks for the feedback. I'll make the changes you suggested over the next few days.
The INSTEON technical document that I used for development is a 246-page document called the "INSTEON Developer's Guide." I believe it's available only as part of the "INSTEON Development Kit" (I've put a link to it at http://www.cls01.com/insteon/#supplies).
The document you referenced looks like a good technical reference for the INSTEON technology but doesn't include a lot of the RS232 serial control protocol information that's needed to develop an application interface to the INSTEON controller. I've also added a link to this doc on the web site.
Scott
I've added comments and posted Javadoc documentation at http://www.cls01.com/insteon/#documentation
INSTEON has a superset of X10 capabilities but it's in the same category of devices that X10 created so it makes some sense to put it in an X10 directory as you mentioned. Just one question to clarify... Should the class be in:
- stamp.peripheral.x10.insteon.Insteon.java, or
- stamp.peripheral.x10.Insteon.java?
Scott
(create a insteon folder inside x10 folder)
Class is looking good.
Thanks.
regards peter
Post Edited (Peter Verkaik) : 4/6/2006 12:57:39 AM GMT
