LCD Line 2
I have a parallel LCD and i have no idea how to access the second line
This is my code so far:
I plan to take out all the flashy stuff and have it so the LCD writes to both lines. I am sure the code is there EG
But I don't know how to incorperate it so it actually does what is says :goes to the 2nd line.
If there is ANYTHING you need to know to further aid your assistance please do ask
Microman171
1 + 1 = 10 Base 2
2 + 2 = 10 Base 4
3 + 3 = 10 Base 6
4 + 4 = 10 Base 8
5 + 5 = 10 Base 10
Post Edited (Microman171) : 2/26/2006 5:40:21 PM GMT
' File....... SW20-EX11-LCD_Demo.BS2
' Purpose.... Essential LCD control
' Author..... (C) 2000 - 2005, Parallax, Inc.
' E-mail..... support@parallax.com
' Started....
' Updated.... 01 JUN 2005
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' This program demonstrates essential character LCD control.
' The connections for this program conform to the BS2p-family LCDCMD,
' LCDIN, and LCDOUT instructions. Use this program for the BS2, BS2e,
' or BS2sx. There is a separate program for the BS2p, BS2pe, and BS2px.
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
E PIN 1 ' Enable pin
RW PIN 2 ' Read/Write
RS CON 3 ' Register Select
LcdBus VAR OUTB ' 4-bit LCD data bus
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
LcdCls CON $01 ' clear the LCD
LcdHome CON $02 ' move cursor home
LcdCrsrL CON $10 ' move cursor left
LcdCrsrR CON $14 ' move cursor right
LcdDispL CON $18 ' shift chars left
LcdDispR CON $1C ' shift chars right
LcdDDRam CON $80 ' Display Data RAM control
LcdCGRam CON $40 ' Character Generator RAM
LcdLine1 CON $80 ' DDRAM address of line 1
LcdLine2 CON $C0 ' DDRAM address of line 2
#DEFINE LcdReady = ($STAMP >= BS2P)
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
char VAR Byte ' character sent to LCD
idx VAR Byte ' loop counter
idx2 VAR Byte ' loop counter2
' -----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
Msg DATA "Line1", 0 ' store message
Msg2 DATA "Line2", 0 ' store message2
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Reset:
#IF (LcdReady) #THEN
#ERROR "Please use BS2p version: SW20-EX11-LCD_Demo.BSP"
#ENDIF
DIRL = %11111110 ' setup pins for LCD
PAUSE 1000 ' let the LCD settle
Lcd_Setup:
LcdBus = %0011 ' 8-bit mode
PULSOUT E, 3
PAUSE 5
PULSOUT E, 3
PULSOUT E, 3
LcdBus = %0010 ' 4-bit mode
PULSOUT E, 1
char = %00101000
GOSUB LCD_Cmd
char = %00001100 ' disp on, no crsr or blink
GOSUB LCD_Cmd
char = %00000110 ' inc crsr, no disp shift
GOSUB LCD_Cmd
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
char = LcdCls ' clear the LCD
GOSUB LCD_Cmd
PAUSE 500
idx = Msg ' get EE address of message
idx2 = Msg2 ' get EE address of message2
Write_Message:
DO
READ idx, char ' get character from EE
IF (char = 0) THEN EXIT ' if 0, message is complete
GOSUB LCD_Out ' write the character
idx = idx + 1 ' point to next character
LOOP
PAUSE 2000 ' wait 2 seconds
Write_MessageLine2:
DO
char = LcdDDRam
char = LcdLine2 ' if 0, message is complete
LOOP
Cursor_Demo:
char = LcdHome ' move the cursor home
GOSUB LCD_Cmd
char = %00001110 ' turn the cursor on
GOSUB LCD_Cmd
PAUSE 500
char = LcdCrsrR
FOR idx = 1 TO 15 ' move cursor l-to-r
GOSUB LCD_Cmd
PAUSE 150
NEXT
FOR idx = 14 TO 0 ' move cursor r-to-l by
char = LcdDDRam + idx ' moving to a specific
GOSUB LCD_Cmd ' column
PAUSE 150
NEXT
char = %00001101 ' cursor off, blink on
GOSUB LCD_Cmd
PAUSE 2000
char = %00001100 ' blink off
GOSUB LCD_Cmd
Flash_Demo:
FOR idx = 1 TO 10 ' flash display
char = char ^ %00000100 ' toggle display bit
GOSUB LCD_Cmd
PAUSE 250
NEXT
PAUSE 1000
Shift_Demo:
FOR idx = 1 TO 16 ' shift display
char = LcdDispR
GOSUB LCD_Cmd
PAUSE 100
NEXT
PAUSE 1000
FOR idx = 1 TO 16 ' shift display back
char = LcdDispL
GOSUB LCD_Cmd
PAUSE 100
NEXT
PAUSE 1000
GOTO Main ' do it all over
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
LCD_Cmd:
LOW RS ' enter command mode
LCD_Out:
LcdBus = char.HIGHNIB ' output high nibble
PULSOUT E, 3 ' strobe the Enable line
LcdBus = char.LOWNIB ' output low nibble
PULSOUT E, 3
HIGH RS ' return to character mode
RETURN
char = LcdLine2
Microman171
1 + 1 = 10 Base 2
2 + 2 = 10 Base 4
3 + 3 = 10 Base 6
4 + 4 = 10 Base 8
5 + 5 = 10 Base 10
Jon Williams
1 + 1 = 10 Base 2
2 + 2 = 10 Base 4
3 + 3 = 10 Base 6
4 + 4 = 10 Base 8
5 + 5 = 10 Base 10
Lcd_Setup:
· LcdBus = %0011······························· ' 8-bit mode
· PULSOUT E, 3
· PAUSE 5
· PULSOUT E, 3
· PULSOUT E, 3
· LcdBus = %0010······························· ' 4-bit mode
· PULSOUT E, 1
· char = %00101000····························· ' multi-line mode
· GOSUB LCD_Cmd
· char = %00001100····························· ' disp on, no crsr or blink
· GOSUB LCD_Cmd
· char = %00000110····························· ' inc crsr, no disp shift
· GOSUB LCD_Cmd
With the proper initialization sequence you can move the LCD to that line with:
· char = LcdLine2
· GOSUB Lcd_Cmd
In short, study Experiment 12 to see how to write to both lines of a 2-line display.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 2/26/2006 5:47:03 PM GMT
BTW where do I put the LcdLine2 command. A little stuck
1 + 1 = 10 Base 2
2 + 2 = 10 Base 4
3 + 3 = 10 Base 6
4 + 4 = 10 Base 8
5 + 5 = 10 Base 10
Post Edited (Microman171) : 2/26/2006 5:53:14 PM GMT
I have the Basic Stamp II educational board and Seetron's BPI-216 LCD.· I don't know what's going on.
Can you help me with this?
Seetron's BPI-216 is a SERIAL LCD, the programming in this thread (Jon's, et al.) concerns parallel LCDs.· You write to your SERIAL LCD using SEROUT instructions.
Chris Savage
Parallax Tech Support
csavage@parallax.com
