Is it possible to read a WKEN_B register?
To read the contents of the WKPND_B register, a “mov !rb, w” instruction is used to copy the contents of the pending reg. into W (reverse transfer). (I found that this is also how to “read” the read registers of the SX48/52 timers by the way.) Does anyone know if this works on the WKEN_B registers, also? How about a TRIS register?
Specifically, I want to be able to change only one bit of the WKEN_B register without affecting the other bits. If I can read it, I can AND mask it to change the specific bit that I want.
It’s too bad Parallax didn’t make it possible to do a “ setb !rb.6 ” instruction.
James Newton, Host of SXList.com
james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
· On the SX48 the TRIS registers are readable and writeable. You can read the register, change one bit, and write it back.
· But the WKPND_B is one of the rare registers that are write-only on the SX48.
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Coming soon... Cheap 4-digit LED display with driver IC·www.hc4led.com
"Sometimes it is better to remain silent and be thought a fool, than to speak and remove all doubt."
Bill F
