Can't read HIGHBIT or LOWBIT of NIBble. Anyone knows how to do?
Hello,
To get more of the BS2's memory, I want to adress, one by one, every pair (4 in total as you know) of each byte.
I can't read either the HIGHBIT neither the LOWBIT of each NIBble. Here's the code. What's wrong with it?
' {$STAMP BS2}
' {$PBASIC 2.5}
ValeurMem VAR Byte
DATA %10110011
Main:
READ 0, ValeurMem
DEBUG BIN4 ? ValeurMem.NIB0 'shows the four last bits (LOWNIB) of the byte - ok
DEBUG BIN4 ? ValeurMem.NIB1 'shows the four first bits (HIGHNIB) of the byte - ok
DEBUG BIN2 ? ValeurMem.NIB0.BIT0 'should show the two last bits of the lowest nibble - but it doesn't...
DEBUG BIN2 ? ValeurMem.NIB0.BIT1 'should show the two first bits of the lowest nibble - but it doesn't...
DEBUG BIN2 ? ValeurMem.NIB1.BIT0 'should show the two last bits of the highest nibble - but it doesn't...
DEBUG BIN2 ? ValeurMem.NIB1.BIT1 'should show the two first bits of the highest nibble - but it doesn't...
END
Roger
Savigny, SWITZERLAND (french speaking part)
' {$STAMP BS2}
' {$PBASIC 2.5}
ValeurMem VAR Byte
DATA %10110011
Main:
READ 0, ValeurMem
END
Roger
Beau Schwabe
IC Layout Engineer
I made this same exercise one hour ago but one level "byte level". Here, it works. But since I have a need for only 4 (0 to 3) results (or possibilities), I want to make the same at nibble level.
Can you help? Following your suggestion, would itbe possible to addition those 2 bits? How?
' {$STAMP BS2}
' {$PBASIC 2.5}
ValeurMem VAR Byte
DATA %00010011
Main:
READ 0, ValeurMem
DEBUG BIN4 ? ValeurMem.LOWNIB, BIN4 ? ValeurMem.HIGHNIB
DEBUG ? ValeurMem.LOWNIB, ? ValeurMem.HIGHNIB
END
Roger
byte: 10100111
nibbles: 1010 0111
pairs: 10 10 01 11
^ my assumption of how you want to break it down
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
What is even stranger to me is that I could find the LOWNIB (NIB0) or HIGHNIB (NIB1) arguments in the help file under "Memory and Variables" ...
Is it really not possible?
Roger
myVar VAR Nib
anyways, the bit modifiers only give you access to one bit at a time
What you can do is create a mask within each nibble %0011 or %1100 and shift right by 2 ">>2"
if you want to access the upper 2 bits of the nibble. This way, if you want you can assign a seperate
variable to the 2-bits that you are interested in. Hope this helps.
' {$STAMP BS2} ' {$PBASIC 2.5} ValeurMem VAR Byte Temp1 VAR Nib 'reserved for the two lower bits of the lower nibble of ValeurMem Temp2 VAR Nib 'reserved for the two upper bits of the lower nibble of ValeurMem Temp3 VAR Nib 'reserved for the two lower bits of the upper nibble of ValeurMem Temp4 VAR Nib 'reserved for the two upper bits of the upper nibble of ValeurMem DATA %10110011 Main: READ 0, ValeurMem Temp1 = ValeurMem.NIB0 & %0011 Temp2 = (ValeurMem.NIB0 & %1100) >>2 Temp3 = ValeurMem.NIB1 & %0011 Temp4 = (ValeurMem.NIB1 & %1100) >>2 DEBUG BIN4 ? ValeurMem.NIB0 'shows the four last bits (LOWNIB) of the byte - ok DEBUG BIN4 ? ValeurMem.NIB1 'shows the four first bits (HIGHNIB) of the byte - ok DEBUG BIN2 ? ValeurMem.NIB0.BIT0 'should show the two last bits of the lowest nibble - but it doesn't... DEBUG BIN2 ? ValeurMem.NIB0.BIT1 'should show the two first bits of the lowest nibble - but it doesn't... DEBUG BIN2 ? ValeurMem.NIB1.BIT0 'should show the two last bits of the highest nibble - but it doesn't... DEBUG BIN2 ? ValeurMem.NIB1.BIT1 'should show the two first bits of the highest nibble - but it doesn't... DEBUG CR DEBUG BIN4 ? ValeurMem.NIB0 'shows the four last bits (LOWNIB) of the byte - ok DEBUG BIN4 ? ValeurMem.NIB1 'shows the four first bits (HIGHNIB) of the byte - ok DEBUG BIN2 ? ValeurMem.NIB0 & %0011 'shows the two last bits of the lowest nibble DEBUG BIN2 ? (ValeurMem.NIB0 & %1100) >>2 'shows the two first bits of the lowest nibble DEBUG BIN2 ? ValeurMem.NIB1 & %0011 'shows the two last bits of the highest nibble DEBUG BIN2 ? (ValeurMem.NIB1 & %1100) >>2 'shows the two first bits of the highest nibble DEBUG CR DEBUG DEC ? Temp1 'shows the decimal value of the last two bits of the lowest nibble DEBUG DEC ? Temp2 'shows the decimal value of the first two bits of the lowest nibble DEBUG DEC ? Temp3 'shows the decimal value of the last two bits of the highest nibble DEBUG DEC ? Temp4 'shows the decimal value of the first two bits of the highest nibble▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
THANK YOU
This is exactly what I needed.
I have never been dealing with the binary operators before so I didn't even know where to look to answer my question.
Again, Beau, thanks a lot. I really appreciate the time you must have spent on my problem.
Thank you.
Roger
You can also do something like this to go the other direction...
' {$STAMP BS2} ' {$PBASIC 2.5} ValeurMem VAR Byte Temp1 VAR Nib 'reserved for the two lower bits of the lower nibble of ValeurMem Temp2 VAR Nib 'reserved for the two upper bits of the lower nibble of ValeurMem Temp3 VAR Nib 'reserved for the two lower bits of the upper nibble of ValeurMem Temp4 VAR Nib 'reserved for the two upper bits of the upper nibble of ValeurMem Temp1 = 3 'or Temp1 = %11 Temp2 = 0 'or Temp1 = %00 Temp3 = 3 'or Temp1 = %11 Temp4 = 2 'or Temp1 = %10 ValeurMem = Temp4 ValeurMem = (ValeurMem << 2) + Temp3 ValeurMem = (ValeurMem << 2) + Temp2 ValeurMem = (ValeurMem << 2) + Temp1 DEBUG BIN4 ? ValeurMem.NIB0 'shows the four last bits (LOWNIB) of the byte DEBUG BIN4 ? ValeurMem.NIB1 'shows the four first bits (HIGHNIB) of the byte▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
'·{$STAMP BS2}
' {$PBASIC 2.5}
temp··· VAR···· Byte
Main:
· temp = $A5
· DEBUG BIN8 temp, CR
· DEBUG REP " "\0, BIN2 temp.NIB1 >> 2, CR
· DEBUG REP " "\2, BIN2 temp.NIB1, CR
· DEBUG REP " "\4, BIN2 temp.NIB0 >> 2, CR
· DEBUG REP " "\6, BIN2 temp.NIB0, CR
Jon Williams
Although your solution is more simple, it doesn't work as I need it. Have a look to what happens when you replace the "BIN2" argument by "BIN".
I'll stick to Beau's solution. In his case, I get for each pair of bits the decimal value calculated as if the byte would only be 2 bits long.
Example: %11100100 ($E4)
After the byte has been decomposed, the decimal values are:
- for bits 2 and 1 = 0
- for bits 4 and 3 = 1
- for bits 6 and 5 = 2
- for bits 8 and 7 = 3
Using caracters (elements) that have only 3 different possible values, I can now store FOUR TIMES MORE datas in the data memory of my BS2 (Bytes X 4)!
Isn't this great?
Roger
