automotive automatic relay
TC
I am installing a 2nd battery into my car. I would like to make a BS1 to monitor the tachometer from the motor, when the tach hits a set speed (around 600 RPM), there would be a delay (around 30sec to 1min) to let the charging system stabelize, then turn on a 200 amp relay to connect the 2nd battery.
my question is could someone please point me in the right deraction.
thanks TC
P.S. sorry for the bad spelling.
thanks TC
Essentially, the BS1 will put out tens of millamps of 5 volt power at tops. So you have to move that signal up to enough amps and automotive voltage [noparse][[/noparse]about 12 volts, right?].
You have two options: solid state and electro-mechanical.
The advantages of using another relay [noparse][[/noparse]the electro-mechanical] are that you can completely isolate the 5 volt side from the 12 volt side with a 5 volt relay AND you can use a Double Pole switch to completely, and redundantly, turn it off. The disadvantages are a bit of noise and it is slower.
The advantages of using solid state are really unclear to me as they never completely turn off, the SSRs are often larger than the mechanical relays, they generate heat, and you can only shut down one side with one relay. Still, it is an option that many people prefer as being more 'high tech'.
What is clear is that you have to protect your solid-state circuits [noparse][[/noparse]including the BS1] from 'fly back' voltage from the relay coil. This is done with a diode. And, it is better to nearly completely isolate the BS1 from the 12volt automotive circuit.
Post Edited (Kramer) : 3/18/2006 8:22:07 AM GMT
Then use another pin of your stamp as an output·to drive·a fet/transistor/relay/ssr (your choice) to actuate your larger relay.
Roughly it would be,
Count ignition pulses over time period
If Pulses are greater than whatever = 600rpm
Start·pause for 30 seconds
verify ignition pulse count
Turn on relay
If Not
Turn off relay
Then you have an automatic relay to only tie your stereo battery to the engine battery when the car is running. Just taking a shot in the dark at what your doing.
Chris
Now for Chris. Would you know where I can info on using an opto isolator? The only thing I know about opto’s is that there is a LED for the input then there is a phototransistor for the output. But I don’t know how to work with the output. I think the picture gave away my true identity, but you are right. I do not want to put too much of a load on my alternator just after startup. I was also thinking of adding an A/D converter to monitor the main battery, and if the voltage is not up to 13.5 volts then the BS1 would wait longer until it is, then it would start the count down.
Good Luck!
www.electronicsforu.com/efylinux/circuit/nov99/panel.gif
So I have no idea of its power requirements for the input.
It could easily exceed the abilities of the ULN2003 and cause it to self-destruct. Probably won't hurt the Stamp though.
It would be best to measure the coil's resistance and do some math. One properly sized FET with diode protection is all you really need on the output.
For the RPM input , the ignition spark data will usually give you the RPM x the number of engine cyclinders.
So to get an actual figure, you merely reverse the the formula.
Of course, if you have a fancy two spark plug per cylinder arangement or Deisel, this would not be the case.
About 2/3's of the way down, the second set of schematics. There its using switches tied to the opto's but it could just as easily be a coil negative.
Its exactly like you said, an LED input with the appropriate current limiting resistor, and then the phototransistor output to your micro controler so now your input pin from your stamp/micro is no longer directly electricaly connected to the voltage, and switched to current instead of voltage based to reduce noise.
Kramer:·· to view the relay, go to the link from above and scroll down about 2/3 the way down. And you can see the relay. ·As I told Bushi I am going to use an automotive relay to control the sr200. Thank you for the formula. I think I might have an idea. Using PULSIN measure the time it takes to go from ON-OFF-ON with the car running, Then put that into memory, and if the time is ever less then I would know if the motor is to speed, if not wait. (Shorter pulse = more tach, longer pulse = less tach). It sucks I was going to use the fuel injector but the ECM (Engine Control Module) knows if there is anything on the injector line. So I have to get a module to take the data bus (CAN Bus) and provide a tach signal.
ChrisP:·· Your project is very interesting. I was going to do something like that a few years back for my ’69 Charger R/T. I was going to make a NOS controller for it. But I found out that after I spent the time and money I would have NOS’s controller, so I just bought it.
Going back to your original problem, the marine industry has many devices to allow two batteries to co-exist. They can allow simultaneous charging, individual or parallel discharge. Either automatic or manual operation.
Look at any marine products distributer for "Battery Isolators".
Cheers
If you are not into 'very beautiful' cable, you can buy your battery cables by the yard at an welding supply.· They sell large diameter red and black for arc welding.· They also sell the end fittings which need to be 'sweat soldered' with a butane torch.· Very flexible, very durible.
Stamptol is right about the 'marine industry' as many boats use second batteries for saftey lighting when moored at night and a dozen other things. They would be much more helpful with variations from the standard automotive set-up.
Many marine engines are just modified automotive engine blocks, both desiel and gasoline. The supporting electrical systems transfer quite easily. You can also get bigger alternators to charge a huge bank of batteries.
Post Edited (Kramer) : 3/22/2006 7:06:26 AM GMT
