altering behavior when a button is depressed for longer than n seconds
Hi,
I have a simple routine for incrementing/decrementing a variable based on button states:
I would like to increment a value by 10 instead of 1 if a button state remains the same for a couple seconds... kind of like how many alarm clocks work.
Any tips on how i could do this ?
Thanks!
Dylan
Get_Buttons:
Btns = %1111 ' enable all four inputs
FOR BtnIdx = 1 TO 5
Btns = Btns & ~BtnBus ' test inputs
PAUSE 5 ' delay between tests
NEXT
'check for a mode switch (switch 0)
IF Btns.BIT0 = 1 THEN
motor_select = motor_select + 1 // 3 ' update motor_select constrain to 0-2
ENDIF
'check for an increase in dt (switch 1)
IF Btns.BIT1 = 1 THEN
dt(motor_select) = dt(motor_select) + 1 'it would be nice to increment this by 10 sometimes...
ENDIF
'check for a decrease in dt (switch 2)
IF Btns.BIT2 = 1 THEN
dt(motor_select) = dt(motor_select) - 1 'it would be nice to decrement this by 10 sometimes...
ENDIF
'check for motor enable/disable (switch 3)
IF Btns.BIT3 = 1 THEN
motorEnable(motor_select) = motorEnable(motor_select) + 1 //2 'constrain to 0-1
'start the clock for this motor
idx = motor_select
GOSUB Set_Time
ENDIF
RETURN
Thanks!
Dylan
· rate1 = rate1 + 1 * btns.BIT1
· IF (rate1 > 10) THEN
··· dt(motor_select)·=·dt(motor_select)·+·10
· ELSE
· ENDIF
Note that the first line of code will either add one to rate, or clear it based on the return value.· You need to be a little careful with this as rate could roll-over from its max value to zero if the variable size is too small for the amount of time the button could be pressed.
Jon Williams
Chris Savage
Parallax Tech Support
csavage@parallax.com
Jon Williams
'check for an increase in dt (switch 1) IF Btns.BIT1 = 1 THEN dt(motor_select) = dt(motor_select) + i i = i + 1 MAX 11 'constrain to NIB size IF(dt(motor_select) < 2 ) THEN dt(motor_select) = 2 i = 1 ENDIF ELSEIF Btns.BIT1 = 0 THEN i = 1 ENDIF 'check for a decrease in dt (switch 2) IF Btns.BIT2 = 1 THEN dt(motor_select) = dt(motor_select) - d d = d + 1 MAX 11 'constrain to NIB size IF(dt(motor_select) < 2 ) THEN dt(motor_select) = 2 d = 1 ENDIF ELSEIF Btns.BIT2 = 0 THEN d = 1 ENDIFnote the hack used to prevent the dt variable from going below 2 ... would a MIN 2 fix this ... :
Any ideas?
Thanks again,
Dylan
Jon Williams
IF Btns.BIT1 = 1 THEN dt(motor_select) = dt(motor_select) + i i = i + 1 MAX 11 'constrain to NIB size IF(dt(motor_select) < 2 ) THEN dt(motor_select) = 2 i = 1 ENDIF ELSEIF Btns.BIT1 = 0 THEN i = 1 ENDIFwith this
Similarly for the second code block. That does not include setting i=1 when motor_select<2, I don't quite see what purpose that serves.
Tracy Allen
www.emesystems.com
