Free memory location at run-time — Parallax Forums
edited 2006-03-12 08:31 in Propeller 1
Is there any way to tell, at run-time, where the "stack/free" area begins in hub RAM?
Phil
  • cgraceycgracey Posts: 14,303
    edited 2006-03-12 08:04
    To find the start of stack/free, you could just say @result from the initial COG in the initial PUB. That will give you the address of the result variable which is in the dynamic stack area.
    Chip Gracey
    Good, that works. Can I assume, then, that the RAM between @RESULT + 4 and $7FFF is available for any purpose and won't get clobbered, or is it being used somehow? If it's being used, is there a "free zone" within it that's guaranteed not to be?
    Phil
