Whats inside a IR reciver?
as I understand it a IR reciver is a photodiode and a IC that does some comparison..
anyone know if this IC function can be replaced by another IC, and then be connected to a larger number of photodiodes?
datahsheet on a recviver.
http://www.elfa.se/pdf/75/07520596.pdf
Chris Savage
Parallax Tech Support
csavage@parallax.com
So much like the same problems in AM radio, the IR tuned into a band [noparse][[/noparse]about 38500Hz, though some manufatures vary this upward toward 41,000Hz].
So what is inside. A IR receiving diode; maybe a sheilded case to receive in one direction, and a band-pass filter. I suppose there might be an amplifier too.
So, you would need an op amp arrangement as your filter and you would need to get enough power out of it to be useful. Personally, op amps are something I don't really like to work with, but it can be done. An osilloscope would help you assure adequate filtering and adequate output [noparse][[/noparse]I don't have one].
I thought that a photodiode plugged into the I/0 of a basic stamp could recognise a osilated signal like 38,5 khz from the background light/noise? I have many photodiodes, and they are hard to use as a dark /light sensor. What are their purpose in life?
Probably more than 3 components.... There are also more than likely a couple of components, RC or LC or both, that form a filter on the front end specifically
tuned to either block or allow specific frequencies in the desired IR frequency range.
Beau Schwabe
IC Layout Engineer
