batteries with homework board?
I know that it is recommended that you do not use anything but a 9v battery with the homework board, but could i use rechargeable AA's instead because 9v batteries are quite expensive. I was thinking about using 2, 3, or maybe 4 rechargeable nimh batteries. Is this a wise thing to do? I am hoping that there wouldn't be a risk of messing up the board.
Jim
In the end, it seems that it's all about getting the LEDs to blink....
Truly Understand the Fundamentals and the Path will be so much easier...
At the time, I thought it was something of an extravagence, but I've never regretted it.
In other words, a 7805 won't generate 5V output on a 6V input. It needs at least 7V input.
