No debugger?
I have read somewhere that the Propeller has no debugger.
Does it have at least the DEBUG output as in BasicStamp ?
·1+1=10
I would bet money that Chip has put some debugging suggestions at least in the official documentation.
'' Put a buzzer on A4 and an RC circuit with photo resistor + cap (like in WAM) on A8 CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ num : "numbers" ' For debugging com : "FullDuplex" ' For debugging BS2 : "BS2_Functions" ' Create BS2 Object CON Buzzer = 4 RC = 8 PUB Start | x BS2.Start com.start(31,30,9600) ' initialize serial comms (rx, tx, baud) Repeat dira[noparse][[/noparse]Buzzer]~~ dira[noparse][[/noparse]RC]~~ outa[noparse][[/noparse]RC]:=1 bs2.PAUSE(10) x := BS2.RCTime(RC,1) com.str(num.toStr(x,10)) ' send to DEBUG, 10 = DEC BS2.freqout(buzzer,100,x)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Martin Hebel
Perform an Employer's Survey of Electronic Technologies Graduates· - Click here!
Personal Links with plenty of BASIC Stamp info
and SelmaWare Solutions - StampPlot - Graphical Data Acquisition and Control
Post Edited (Martin Hebel) : 3/7/2006 6:06:07 PM GMT
Greetings from Germany,
G
''******************************* ''* Simple Debug Object * ''* (C) 2006 Parallax, Inc. * ''******************************* OBJ uart : "FullDuplex" PUB start(baud) : okay '' Starts uart object (at baud specified) in a cog '' -- uses Propeller programming connection '' -- returns false if no cog available okay := uart.start(31, 30, baud) PUB startx(rxpin, txpin, baud) : okay '' Starts uart object (at baud specified) in a cog '' -- uses specified rx and tx pins '' -- returns false if no cog available okay := uart.start(rxpin, txpin, baud) PUB stop '' Stops uart -- frees a cog uart.stop PUB putc(txbyte) '' Send a byte to the terminal uart.tx(txbyte) PUB str(stringPtr) | i '' Print a zero-terminated string repeat i from 0 to strsize(stringPtr) - 1 putc(byte[noparse][[/noparse]stringPtr][noparse][[/noparse]i]) PUB dec(value) | i, z '' Print a signed decimal number if value < 0 -value putc("-") i := 1_000_000_000 z~ repeat 10 if value => i putc(value / i + "0") value //= i z~~ elseif z or i == 1 putc("0") i /= 10 PUB hex(value, digits) '' Print a hexadecimal number value <<= (8 - digits) << 2 repeat digits putc(lookupz((value <-= 4) & $F : "0".."9", "A".."F")) PUB bin(value, digits) '' Print a binary number value <<= 32 - digits repeat digits putc((value <-= 1) & 1 + "0") PUB getc : rxbyte '' Get a character '' -- will block until something in uart buffer rxbyte := uart.rx▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Jon Williams
Cheers, Chris
z~··· clear z to 0 (false)
z~~·· set z to -1 (true)
<-··· bitwise rotate left
Many of the operators are combined with assignment as in other languages:
x //= 5 is the same as x = x // 5
In truth, I did nothing but assemble the code; the routines were created by Chip.
Jon Williams
elseif z or i == 1
interperted as elseif z or (i == 1)
or as elseif (z or i) == 1
I almost always use () since I don't trust my memory on how this particular language does it.
· elseif z or (i == 1)
because the == operator has higher precedence than or.
Jon Williams
Under "normal" circumstances, precedence would, indeed, make the order clear, but with our experience with the Stamp's interpretation...[noparse]:)[/noparse]
Truly Understand the Fundamentals and the Path will be so much easier...
·1+1=10
Post Edited (Paul Baker) : 3/8/2006 6:48:48 PM GMT
Jon Williams
[code]
You may also use a modified version of Dave's sample 04 (see http://forums.parallax.com/showthread.php?p=574524) to display various information on a video screen.
G
yes, I absolutely agree - a video monitor together with some code like your EXAMPLE 09 is the most valuable debugging tool for the Propeller (much more informative than blinking LEDs). Thank you for posting this example.
G
I think Parallax needs to get ready to sell lots of monitors.· Thanks for the support.
Dave
Jon Williams
What do the display specs need to be to run directly from a Propeller ?
Chris
·1+1=10
Jon Williams
Jon Williams
After using Jon Williams' debug object for awhile, I found that I needed something simpler yet: just a self-contained object that twiddled an output pin directly -- no inputs -- and provided an inverted signal that would drive my PC's RxD pin without additional circuitry. Here's the result:
[i][b]''*******************************[/b][/i] [i][b]''* Simple Debug Object *[/b][/i] [i][b]''* (C) 2006 Parallax, Inc. *[/b][/i] [i][b]''* Modified by Phil Pilgrim *[/b][/i] [i][b]''*******************************[/b][/i] [i][b]'' This debug object, originally posted by Jon Williams, has been modified to[/b][/i] [i][b]'' provide output only, and without involving FullDuplex, which uses another cog.[/b][/i] [i][b]'' Output is provided inverted, so the 3.3V signal level can drive the PC's RxD[/b][/i] [i][b]'' pin directly. (Note: Not all PC serial ports will work with a 0 to 3.3V signal.)[/b][/i] [b]VAR[/b] [b]long[/b] BaudClock [b]long[/b] TxMask [b]PUB[/b] start(txpin, baud) [i][b]'' Initializes the baud delay factor, and the pin direction and level.[/b][/i] BaudClock := clkfreq / baud TxMask := 1 << txpin [b]outa[/b] &= !Txmask [b]dira[/b] |= TxMask [b]PUB[/b] stop [i][b]'' Changes the pin back to an input.[/b][/i] [b]dira[/b] &= !TxMask [b]PUB[/b] str(stringPtr) | i [i][b]'' Print a zero-terminated string[/b][/i] [b]repeat[/b] i [b]from[/b] 0 to [b]strsize[/b](stringPtr) - 1 putc([b]byte[/b][noparse][[/noparse]stringPtr][noparse][[/noparse]i]) [b]PUB[/b] dec(value) | i, z [i][b]'' Print a signed decimal number[/b][/i] [b]if[/b] value < 0 -value putc("-") i := 1_000_000_000 z~ [b]repeat[/b] 10 [b]if[/b] value => i putc(value / i + "0") value //= i z~~ [b]elseif[/b] z [b]or[/b] i == 1 putc("0") i /= 10 [b]PUB[/b] hex(value, digits) [i][b]'' Print a hexadecimal number[/b][/i] value <<= (8 - digits) << 2 [b]repeat[/b] digits putc([b]lookupz[/b]((value <-= 4) & $F : "0".."9", "A".."F")) [b]PUB[/b] bin(value, digits) [i][b]'' Print a binary number[/b][/i] value <<= 32 - digits [b]repeat[/b] digits putc((value <-= 1) & 1 + "0") [b]PUB[/b] putc(txbyte) | time [i][b]'' Send a byte to the pin (inverted).[/b][/i] txbyte := !((txbyte | $300) << 1) time := [b]cnt[/b] [b]repeat[/b] 11 [b]waitcnt[/b](time += BaudClock) [b]outa[/b] := [b]outa[/b] & !TxMask | (txbyte & 1 > 0) & TxMask txbyte >>= 1My PC works fine with the Propeller's 0 and 3.3V signal levels (in lieu of -10 and +10), but this may not work for everyone.
Post Edited (Phil Pilgrim) : 3/18/2006 5:15:39 AM GMT
Just started to get my Propeller chips up and running ( Been using javelin and BS2's for a while.)
I used the PC_Debug example ( From N&V) running at 460,800bps and it works fine. Running at 9600bps, the output stops with a corrupt character in hyperterminal. Any-one experienced any issues running at a lower speed?
Any help much appreciated,
PS - I really want to get this running as I am (still) putting together and Videocamera remote controller. 2 cogs will be Sony LANC to controll video cameras, 1 cog for PWM for the Pan/Tilt controller, and I will still have cogs left over for user interface, debug, etc. This is the answer to my dreams. ( LANC is serial at 9600bps - with some twists, which is why I am trying things out at a lower speed.)
I'm using the I2C object with the Matrix Orbital LK202-25 which Parallax sells (although I don't know if the Parallax version has the I2C Interface). This allows me to extend the interface the EEProm is connected too and have debug output without using any additional pins. I'm working on a SPIN object that will support the LK202-25 I2C Commands. This little device also allows a 5x5 keybpard to be attached to it allowing LCD output and keyboard input without using additional Propeller pins. I use this very setup throughout Embedded Systems Desktop Integration with the BASIC STAMP. I'm currently porting that over to the propeller. When completed there will be a debug supervisor that will hopefully offer single step, register display, and some other goodies for assembly program debugging.
Oliver
