BS2 Library Testing
Martin HebelMartin Hebel Posts: 1,231
edited 2006-03-06 - 05:01:49 in Propeller 1
I've been playing around making a BS2 Library, so far with PULSOUT, PULSIN, FREQOUT, PAUSE and RCTime. Here's some sample code to use it. One cog is reading RCTime on a PhotoR and another Cog is using that data to sound a tone on a buzzer. They share a common global variable so they can both be doing their own thang simultaneously:
{{  ____________________________________________________________________
    Test of BS Function Library
    This test reads RC Time of Cap & Photoresistor on A4 on one cog
    and plays frequency of RCTime value on another cog from A0
    for multiprocessor BS2.  Data is passed using global variable.
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
VAR
  Long RC_Val, stack1[noparse][[/noparse]50], Stack2[noparse][[/noparse]50]
CON                                        ' Set Pins
  Buzzer = 0                               ' Speaker
  PhotoR = 4
OBJ
  BS2 : "BS2_Functions"                    ' Create BS2 Object
PUB Start
    BS2.start                              ' Initialize BS2 library
    cognew(GetTime,@stack1)                ' Start a cog to run RCTime routine
    cognew(SoundTime,@stack2)              ' Start a cog to run FREQOUT routine
    'cognew(SoundTime2,@stack2)            ' Start a cog to run FREQOUT_SET routine - Use this instead one for smoother tone
PUB GetTime                                '' Routine to read RCTime and store in global RC_Val
  repeat
     dira[noparse][[/noparse]PhotoR]~~                        ' set to output
     outa[noparse][[/noparse]PhotoR]:=1                       ' set high
     BS2.Pause(10)                         ' allow to charge for 10mS
     RC_Val:= BS2.RCTime(PhotoR,1)         ' read RCTime and store in RC_Val
     BS2.Pause(500)             ' Pause this routine for 1/2 second to prove other still runs
PUB SoundTime                              '' Routine to sound frequency
    repeat
      BS2.Freqout(Buzzer,100,RC_Val)       ' Continually sound buzzer at RC_Val value
PUB SoundTime2                             '' Uses modified FREQOUT_SET Command
                                           '' Sounds tone continually, only updates when new value
    Repeat
      BS2.Freqout_SET(Buzzer,RC_Val)
Martin Hebel
Perform a Survey of Electronic Technology Employers - Click here!
Personal Links with plenty of BASIC Stamp info
and SelmaWare Solutions - StampPlot - Graphical Data Acquisition and Control
Post Edited (Martin Hebel) : 3/3/2006 3:57:24 PM GMT
  • Kaos KiddKaos Kidd Posts: 614
    edited 2006-03-03 - 15:26:48
    Very interesting.
    #1: PUB Start is a "key word" routine, or event?· If so, are there other "key" routines / events ?
    #2: Reading the CogNew command, I can see you specify the PUB (or PRI?) routine for that cog to run, and it's stack space.· Can you pass paramiters?
    #3: The VAR RC_Val, definded at the top of the file indicates the VAR is globally accessable;·
    ····· To be private, I would have declared them in the PUB or PRI routine?
    #4: Seeing the PUB GetTime, it doesn't use any VARs, but it requires·VAR space ( ie: @Stack1 in the command ) ?
    #5: What would be the difference in declaring PUB GetTime or PRI GetTime ?·
    Oh, and one last one...
    So, a PUB Routine_Name would indicate a Global level Routine, ... Ok... hang on a second... I think someone just turned on the lights...
    Does the compiler looks at things like this:· ( this is a question...)
    VAR
      Long Global_Var, Cog1Stack[noparse][[/noparse]50], Cog2Stack[noparse][[/noparse]50]
    PUB Start
      CogNew(Cog_1Code,@Cog1Stack)         'Start up first cog using cog 1 code
      CogNew(Cog_2Code,@Cog2Stack)         'Start up second cog using cog 2 code
    PUB Cog_1Code
      VAR
        Long Private_var                   'THis would be a VAR that's only available in this routine, right?
      repeat                               'Do until the end of time
      ...                                  'Some worth while code that
      ...                                  'actually does something
      GOSUB Cog_1_Routine                  'Call a private routine within this cog's code...
      ...                                  'Some more code that
      ...                                  'Continues to do something
      GOSUB Global_Routine                 'Call a routine that's globally accessable by all Cogs
      GOSUB Cog_1_Routine                  'Call the pritate routine for this cog's code again...
      ...                                  'The rest of the code that
      ...                                  'finishes the something this cog does
    PRI Cog_1_Routine
      ...                                  'The Rountine called by Cog 1, and can only be called by cog 1
      ...                                  'This does some thing and then
      RETURN                               'returns to the caller (should be code in cog 1 code
    PUB Cog_2_Code
      REPEAT                               'Again, do until the end of time
      ...                                  'This is Cog 2's code...
      GOSUB Global_Routine                 'THat calls the global routine
      ...                                  'And does some nifty stuff.
    PUB Global_Routine
      ...                                  'This is a global routine to be used by any cog as needed.
      ...                                  'This does some stuff then
    If this is getting too detailed then skip it, I'll wait for the docs to be published.·
    THis code is very is easy·to read and understand.
    Thanks for posting it!
    Just tossing my two bits worth into the bit bucket
    KK
    edited 2006-03-03 - 15:42:49
    The way a routine is declared is:
    PUB Routine_Name(arg0, arg1, arg2):return_value | local_variable1, local_variable2
    A private function (a routine only called by routines within the object) is declared the same way but with PRI instead of PUB.
    The arguments, return value and local (private) variables are all optional so you can get functions that look like:
    PUB Routine1
    PUB Routine2(pin1, pin2)
    PUB Status_Check:OK
    PRI Do_something | i, t
    PRI Do_something_else:Status | h,k
    ·1+1=10
  • Martin HebelMartin Hebel Posts: 1,231
    edited 2006-03-03 - 15:56:03
    I'll start with the easier ones first [noparse]:)[/noparse]
    PUB is a public function/method/subroutine (or whatever you care to name it, haven't read the full docs yet to see conventions)· This means if the program you see was used as an object for another file, those functions would be accessible.· If they were PRI, they wouldn't be.
    When the stack space is address is passed, both programs can have access to the same memory locations, meaning you can write in one and read in another.· When starting an Assembler COG, the pointer is passed also so it can be shared through the ASM code as well!· Potent, huh?
    Yes, it is global to all the functions, not matter which cog it's in.· To be private and local, it would be declared in the function:
    PUB· ReadMe (passed1, passed2) | mylocal1, mylocal2
    Yes, not an expert at this yet, still learning, but the functions that routine calls needs stack space for the variables it may use.· This part gets tricky on how much to allocate.
    I think I answered this in #1
    The BS2_Functions spin file uses PUBs like RCTIme so they can be accessed as object function in the code you·see.· It may also have PRI functions that would NOT be accessible to the test code you see.
    Maybe I should post my BS2_Functions code as well later.
    I'll have to take a closer look at the code you wrote later in depth.· Duty calls.
    Glad it helped light some lights [noparse]:)[/noparse]
    -Martin
    Martin Hebel
    edited 2006-03-03 - 16:51:25
    Here is what's been done so far to create the BS2 Functions.· This is the code that is created as an object by the earlier code to be used.· Even though this gets a little complex, the end user only has to reference it as I did in the test example.
    {{ ________________________________________________________________________
      BS2 Function Library
      Functional Equivalents of many BS2 Functions
      Version 0.5
      3/2/06
      Contact: Martin Hebel   [url=mailto:martin@selmaware.com]martin@selmaware.com[/url]
      To use include in code:
      OBJ
      Start Object with:
        BS2.Start
      Use Functions as:
         BS2.FREQOUT(pin,duration,frequency)
         variable = BS2.PULSIN(pin,state)
    OBJ
      sqWave : "Square Wave Object"              ' Import square wave cog object from Andy Lindsey
    var
      long s, ms, us,Last_Freq
    PUB Start
      s  := clkfreq                              ' Clock cycles for 1 us
      ms := clkfreq / 1_000                      ' Clock cycles for 1 ms
      us := clkfreq / 1_000_000                  ' Clock cycles for 1 s
      Last_Freq := 0
    PUB PULSOUT(Pin,Duration)  | clkcycles
    '' Accepts pin # and duration in 2uS increments
    '' Smallest value is 10 allowed is at clkfreq = 80Mhz, 20 at 40Mhz, etc
      ClkCycles := (Duration * us * 2 - 1250) ' 1200 is offset for processing time
      dira[noparse][[/noparse]pin]~~ ' set to output
      !outa[noparse][[/noparse]pin]                                                  ' NOT output
      waitcnt(clkcycles + cnt)                                    ' Wait time
    PUB PULSOUT_1uS(Pin,Duration) | ClkCycles
    '' Accepts pin # and duration in 1uS increments
    '' Smallest value allowed is 20 at clkfreq = 80Mhz, 40 at 40Mhz, etc
      ClkCycles := (Duration * us-1050)
      waitcnt(cnt + clkCycles)                               ' Wait time
    PUB PAUSE(Duration) | clkCycles
    '' Accepts time in mS
    '' Smallest value is 2 at clkfreq = 5Mhz, higher frequencies may use 1
       waitcnt(cnt + (Duration * ms-2300))
    PUB PULSIN (Pin, State) : Duration
    '' Reads duration of Pulse on pin defined for state, returns duration in 2uS resolution
       Duration := PULSIN_1us(Pin, State)/2
       Return
    PUB PULSIN_1uS (Pin, State) : Duration | ClkStart, clkStop, timeout
    '' Reads duration of Pulse on pin defined for state, returns duration in 1uS resolution
       DIRA[noparse][[/noparse]pin]~
       waitpne(State << pin, |< Pin, 0)                     ' Wait for opposite state ready
       waitpeq(State << pin, |< Pin, 0)                     ' Wait for state to start
       ClkStart := cnt                                      ' Save counter
       waitpne(State << pin, |< Pin, 0)                     ' Wait for opposite state to end
       clkStop := cnt                                       ' Save stop time
       Duration := ((clkStop - ClkStart) * 1000 / (clkfreq / 1000)) '  calculate in 1us resolution
       Return
    PUB FREQOUT(Pin, Duration, Frequency)
    '' Plays frequency defines on pin for duration in mS, does NOT support dual frequencies.
       dira[noparse][[/noparse]pin]~~                                            ' Set direction to output
       sqwave.Update(Pin,Frequency,0)                         ' start with Andy's freq gen library
       Pause(Duration)
       sqwave.Update(Pin,0,0)                                 ' Stop freq
       Return
    PUB FREQOUT_SET(Pin, Frequency)
    '' Plays frequency defines on pin INDEFINATELY does NOT support dual frequencies.
    '' Use Frequency of 0 to stop
       If Frequency <> Last_Freq                               ' set freq if different
          Last_Freq := Frequency
       Return
    PUB RCTIME (Pin,State):Duration | ClkStart, ClkStop
    '' Reads RCTime on Pin starting at State, returns discharge time scaled to BS2 values
       DIRA[noparse][[/noparse]Pin]~
       Duration := ((clkStop - ClkStart) * 1000 / (clkfreq / 1000)) * 100/130
                                           ' calculate in 2us resolution, scale for BS2
       Return
    Also note the documentation the Spin IDE makes from the code above: (Ok, still learning here, so may be better ways, but....)
      Version 0.5
      3/2/06
      OBJ
      Start Object with:
        BS2.Start
      Use Functions as:
    Object "bs2_functions" Interface:
    PUB  Start
    PUB  PULSOUT(Pin, Duration)
    PUB  PULSOUT_1uS(Pin, Duration)
    PUB  PAUSE(Duration)
    PUB  PULSIN(Pin, State) : Duration
    PUB  PULSIN_1uS(Pin, State) : Duration
    PUB  RCTIME(Pin, State) : Duration
    Program:      94 Longs
    Variable:      4 Longs
    __________
    PUB  Start
    PUB  PAUSE(Duration)
     Accepts time in mS
    Martin Hebel
  • inakiinaki Posts: 262
    edited 2006-03-03 - 17:10:52
    Good work Martin, I think your objects will be the first thing I will·use on Propeller.
    What about SERIN/SEROUT ?
    edited 2006-03-03 - 17:19:03
    Someone else is working on SERIN/SEROUT, but I may tackle it this weekend just for fun/learning along with SHIFTIN/SHIFTOUT (as slave or master) and COUNT. A big issue will be trying to do this all in Spin. The fact that this much works from one interpretive language mimicing another tell you alot about the Propellers ability! Some functions could use ASM to do the work, but I am trying to keep it all in Spin so that each cog could acting like a BS2. With ASM, another cog would need to be gobbled up for that code. Also, allows end users to modify the functions for their own 'extended BS2' functionality more easily.
    Thanks inaki,
    Martin
    Martin Hebel
    edited 2006-03-03 - 17:30:32
    SERIN and SEROUT have already been defined and are availible in the objects provided with the IDE, they were not created to mimic the way PBASIC does it, but they work nonetheless.
    Martin, so you are doing SHIFTIN/OUT in spin? I found spin·to woefully inadequate for high speeds, Ive tossed the spin version and am presently working on ASM to define them with spin wrapper functions. Im following the full_duplex model in it's operation. Though you may find a speedier way to do it in spin than my first attempt.
    ·1+1=10
    Post Edited (Paul Baker) : 3/3/2006 5:34:28 PM GMT
    edited 2006-03-03 - 17:53:06
    Hi Paul, I'm going to give it shot. From my experience with PULSIN/OUT, I can control down to 20uS, which should be quick enough for a 16Kbps SHIFTIN/OUT. But whether I can pull it off or not, I'm sure I'll learn something on the journey [noparse]:)[/noparse]
    -Martin
    Martin Hebel
    edited 2006-03-03 - 17:55:02
    I'm going to try half-duplex, just like the BS2 since that's what I'm trying to emulate, so it'll cut down some overhead on SHIFTIN/OUT.
    -Martin
    Martin Hebel
    edited 2006-03-03 - 18:02:53
    Gotcha, good luck, Ive opted to provide a single full duplex asm version, then different wrapper functions will interact in different ways with the asm (SHIFTOUT will feed data in, but ignore the result, SHIFTIN will set the data in to 0 and return the result). The benifit of using spin is the ability to have the cog execute the code directly, my asm approach requires spawning a new cog and having a monitor detecting when a serial function is requested.
    ·1+1=10
    edited 2006-03-03 - 20:50:45
    Wow...
    This is resembling something like a 3G IDE... (Like the functionality of the vb 6 IDE)..
    Martin, thanks a lot for explaining, and with your answers (and the code!), it makes a whole lot more sence.
    I like the way the code 'reads'.... easy to follow and understand...
    Very memory effencant (sp!)...
    Ya, the lights are getting bright... I'll get my shades and continue on...
    I cant wait...
    I have been a VB programmer sence VB DOS (ver 1.0), and all the way up through .net 2005... so, what your building with the objects, and the modeling
    is very much like class and oop in VB... very VERY simular... issues are... no GIU (Ok, I can live with that... make one out of LCD and some buttons...)
    No "canned" events... (you would make events from watching pins...)
    The way you are calling things objects are VERY simular to VB's classes... public and private functions and subs... delercations and returns...
    Still, if you know VB classes, then the only thing to do here is learn the syntax of the language and to program within it's memory limits.
    Still, not much of an issue...
    Man, this is exciting. I can see dozens of usages...
    I will add, your code examples are awesome to read. I can actually understand without know the language syntax, what your are doing.. (I guess your style helps !).
    April isn't gonna get here fast enough!.
    Questions about the IDE folks:
    #1: Can it PLEASE compile without the propeller dev board attached?
    #2: Does it have a object explorer ??
    #3: Project based, not file based? (IE, A project can have a number of files with it.)
    #4: Proper casing of declared vars. IE, if you delcare VAR Ddiksoak, type in ddiksoak, it will change it to Ddiksoak
    #5: Printer support (for printing out code!)
    Lastly, do you believe you will support the tokenizer so others can make custom IDE's ?
    Ok, I know I'm ranting here, but I'm excited...
    I.. I.. Ok, I'll park it...
    THanks again for all the information, the code (espically the code) and the help!
    One humbled kidd, Kaos Kidd that is
    KK
    edited 2006-03-03 - 21:14:26
    kaos kidd said...
    questions about the ide folks:
    #1: Can it please compile without the propeller dev board attached? yes, f9 compiles but doesn't program the propeller·
    #2: Does it have a object explorer ?? yes
    #3: Project based, not file based? (ie, a project can have a number of files with it.) yes, its easier if you have 1 project/directory
    #4: Proper casing of declared vars. Ie, if you delcare var ddiksoak, type in ddiksoak, it will change it to ddiksoak ide is case insensitive
    #5: Printer support (for printing out code!) they are just text files, id have to look if it prints from·within the ide·(probably does in order to easily·print the special unicode characters)
    lastly, do you believe you will support the tokenizer so others can make custom ide's ? you'll find the ide so well designed that you wont want a different ide if you are working with windows. The compiler is written in 386 assembler, so mac users will have to wait.
    ·1+1=10
  • Beau SchwabeBeau Schwabe Posts: 6,432
    edited 2006-03-03 - 22:11:29
    Kaos Kidd said...
    [url=mailto:bschwabe@parallax.com]Beau Schwabe[/url]
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/3/2006 10:27:43 PM GMT
    1075 x 607 - 141K
    edited 2006-03-04 - 13:17:10
    Ok Paul and Beau... Awesome!
    THanks guys, really.
    I can't wait!
    KK
  • danieldaniel Posts: 231
    edited 2006-03-06 - 01:59:08
    Martin Hebel said...
    ...Some functions could use ASM to do the work, but I am trying to keep it all in Spin so that each cog could acting like a BS2. With ASM, another cog would need to be gobbled up for that code....
    and
    Paul Baker said...
    ...Ive opted to provide a single full duplex asm version, then different wrapper functions will interact in different ways with the asm....The benifit of using spin is the ability to have the cog execute the code directly, my asm approach requires spawning a new cog and having a monitor detecting when a serial function is requested.
    I have several questions that these two statements trigger.
    Am I to understand that·a Spin function/procedure cannot have in-line assembly?
    Does any assembly routine require its isolated COG to execute in?
    I just reread the documents on the propeller product page, and apparently there no provision for in-line assembly.· For sume reason, I just assumed that there would be.
    Should I assume that starting an assembly routine in a COG is transparent to the Spin programmer, for does the Spin programmer need to pay attention to the typical details of multi-processor/multi-task interactions?
    Daniel
    edited 2006-03-06 - 02:19:58
    daniel said...
    and
    Paul Baker said...
    I just reread the documents on the propeller product page, and apparently there no provision for in-line assembly.· For some reason, I just assumed that there would be.
    Should I assume that starting an assembly routine in a COG is transparent to the Spin programmer, or does the Spin programmer need to pay attention to the typical details of multi-processor/multi-task interactions?
    Daniel
    edited 2006-03-06 - 03:44:47
    daniel said...
    Daniel
    As I understand it:
    The Spin interpreter takes up the entire cog.· To have any assembly requires a different cog to run it in.· Also, unlike ASM, C or SX/B which are compiled, Spin is in an interpreted language using tokens (byte codes), so in-line assembly is not possible.
    Now, if you have multiple jobs for assembly, data can be shared between a Spin cog and a pASM cog to trigger events or simply for data sharing.
    Starting an assembly cog is just a matter of starting a new cog and declaring the assembly orgin to use (though I haven't gotten to playing with assembly programming yet on the Propeller).
    Martin Hebel
    Perform an Employer's Survey of Electronic Technologies Graduates· - Click here!
  • pjvpjv Posts: 1,903
    Hi Daniel;
    I have just posted a "Propeller Overview" section that I believe answers your questions.
    Cheers,
    Peter (pjv)
