SXB.exe Windows Error — Parallax Forums
Mike CookMike Cook Posts: 829
edited 2006-03-05 17:56 in General Discussion
Was working in SX/B this morning and made a bobo in my code, went to RUN>Compile and got this:
Clicking on 'Click Here' gives you this screen:
I realize this is a result of my error but did not expect SXB.exe to do this. Though I would report this.
Attached is a small SX/B program to demonstrate this. You can't do a IF, THEN, ELSE, ENDIF, EXIT
Can anyone else reproduce this?
"OEM NMEA GPS Module" Now available on ebay for only $17.49
Product web site: http://www.allsurplus.net/Axiom/
    edited 2006-03-04 18:13
    I just checked and that error gets trapped in the latest [noparse][[/noparse]internal] version -- we're working hard to get that released soon.
    Jon Williams
    edited 2006-03-04 18:15
    SWEET!!!!!!!!!!
  • Jim FouchJim Fouch Posts: 395
    edited 2006-03-05 15:36
    I have ran into simillar problems with SX/B in the past. Every time I find that it's a typo on my part. Usually if you use the TRIS_ command with out any parm. The only way I found to fix this is use notepad to open the SXB file and fix the typo.
  • BeanBean Posts: 8,129
    Jim,
    Can you post an example SXB file that causes the problem ?
    Bean.
    "SX-Video·Module" Now available from Parallax for only $28.95
    http://www.parallax.com/detail.asp?product_id=30012
    "SX-Video OSD module" Now available from Parallax for only·$49.95
    http://www.parallax.com/detail.asp?product_id=30015
    Product web site: www.sxvm.com
    "Wise men know when they're right. The wisest also·know when they're wrong."
