2 Wheel Robot
··· New to Robotics and I was thinking about building a 2 wheel robot. But since I have not done anything like that in the past I thought I would ask. Is it enough to just have a large low center of gravity to balance a robot with only two wheels? Has anyone done anything along those lines?
No, it takes a good deal more than just a low center of gravity. You must be able to detect and respond to situations where the mobile platform is tipping too far forward, or too far backwards. This can occur even during times of acceleration, de-accelleration and/or braking. It also can obviously occur going up or down hill. Two wheeled pllatforms are really quite advanced by comparison to other 3-4 or more wheeled designs.
Bruce Bates
<!--StartFragment -->
http://forums.parallax.com/showthread.php?p=570699
It uses standard boe-bot parts, except the floppy disk case I used for the body and the simple 4-button RC control to navigate it around.
You might want to try this before attempting more advanced setup...
Regards, Thanos
Greekbotics: Greek Robotics Forum
That is what I had in mind only on a much larger scale. The only thing I have to lose is time so I think I will give it a try. If you have any other advice for me please contact me vai my email address. I would be most thankful for any advice you can offer.
Ken
Its a long step to switch from theory to operation. When I joined parallax forums, one and a half years now, I was totally newbe in electronics and microcontrollers and decided to start with simple robots like the crawler my avatar shows.
I've had seen a 2 wheels robot design that was presented by a parallax customer but it was impossible to build it cause of my lack o knowledge in programming that time. http://www.parallax.com/html_pages/resources/custapps/app_bway.asp
Now I learned ways to make it·from the simplest parts and most efficient code around. But its after years of expierence in making other type of robots and minor electronic projects that allowed this design to come easy as that. And there is more yet to be learned before I'm able to make in work in larger scale model!
Thanos
PS. kenwtn,·you don't mention anywhere your e-mail address...
Post Edited (Tronic (Greece)) : 3/4/2006 1:11:08 PM GMT
You also need large wheels: http://forums.parallax.com/showthread.php?p=572161·I am trying to use CDs glued together but you can use parallax wheels if you want to put like a safety arm that bounces the bot back if it is about to tip over. I did and it works and look fine. I just want the large wheels to see if it could work without the safety arms.·Safety arms touch the ground only when the servos are quickly accelerated. You can use ramping to get rid of this problem.
·on····· plane··········································, when catching ducks
"In this house, we obey the laws of thermodynamics!"
http://profiles.yahoo.com/jsmasterking
Post Edited (jsmasterking) : 6/5/2006 10:54:24 PM GMT
Post Edited (jsmasterking) : 6/5/2006 10:54:49 PM GMT
Well the images are of the front and the back. On the first image, bend the top flap back and the bottom two flaps back also. On the second image bend the bottom flap and stick the two things together (I used scotch tape and foam-core boards). The two large flaps and the body will make a rectangular box. Put two pieces of cardboard or foam perpendicular to each other making and X to keep the box from collapsing. Print the picture so that the servos will fit in the holes. Insert the servos from the top and slide into toward the bottom. Mount the batteriepack on the bottom and the controller on the top. For the safety arm, I used a small pocket fact book. You can use nuts and bolts to secure everything but take extra care when making holes for them. Remember rubber bands are a little armature but sometime armature is the way to go.
Post Edited (jsmasterking) : 6/5/2006 10:53:41 PM GMT
