looking for the right crimping tool
I am looking for the right crimping tool for crimp contacts that are for .100" female housing. I have seen alot of different tools just don't know which one is the right one. Thanks guys and girls.
-Matt
-Matt
I've looked at other ratcheting types but haven't purchased yet.· They run around $70.
Chris I.
They're like the little things on the end of your shoelace (can't remember the funny name)....these ferrels go on to the end of wire and you crimp them on. So you actually get a more rigid surface to put in to WAGO blocks or phoenix connectors (those green blocks with the screw that pushes down on the wire).
Excelite sells the crimper for a few bucks!!
The crimp looks square on the end of the wire. Can buy different sizes.
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
for example, if you use Jameco Part 100765·female connectors that look like this,
then you would use Jameco Part 99442 crimper.
Jameco actually provides all this info for each of the female connectors and crimpers they sell.
http://marvin3m.com/connect/
-Matt
Post Edited (Matt Battle) : 3/3/2006 7:16:57 PM GMT
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=227492
I have one and it works okay, but it's a little large and clunky·for crimping the smaller KK terminals.
-Matt
Normally if I don't like the result the first time, I'll try to salvage it by soldering.
I don't really think that tool I linked is all that good for the KK type, but any of the better ones are going to cost a whole lot more, and it can get the job done with a little practice and patience.
If you've never really made crimped connectors before, try to learn as much as you can first, read that web page I linked to above and do a google search on "how to crimp".
- Rick
I really like this simple crimp tutorial that Scott Edwards has on his web site here:
http://www.seetron.com/lcd_an2.htm
Scott shows just how its done and what·header pins·and·crimp tool he uses - he even gives the Jameco part numbers to make it easy.· Looks like the same crimp tool that others have mentioned.
Tim
Edit:·Forgot to mention that you·should look·toward the bottom of that page.
The pins and sockets are used for wire sizes from #22 through #30. My experience has been when using smaller than #22 stranded wire, apply a bit of solder to the wire end to "bulk it up" so it doesn't pull out of the crimp.
I use the connector shown in Steve Joblin's post for robot point-to-point connections. I make my connections between .025 square pin headers I mount in my circuit boards. Then, these connectors are crimped and soldered to the ends of #24 stranded wire. I cover the connector with a bit of heat shrink tubing. This connection process allows for quick and fairly secure placement of wires on a board.
