Hobby DMM
Good Evening! I am in need of some suggestions from my fellow stampers... I am seeking advice on a Multimeter purchase. I'm not after Top of the Line - a full featured Fluke is not an option. Basically, I am after a good DMM that will perform most functions that are frequently used in electronic circuit design. I have the parralax scope kit - I really loved the idea of using my PC for my scope. (Its right by my electronics work bench.) I'm not out to bust my wallet either·- anyone have any brand/model suggestions - or at least some pointers on what brand(s) are OK and what brands would make better door stops... Thanks a lot in advance!
~GS
~GS
Although handy is having the diode/continuity checker and the amperage section!
Another bonus, but really not all that accurate, is the conponent tester. You can put a capacitor across the leads and it'll give you the value...or there are ones with the transistor plug in to tell you the gain..etc.
You can also get meters that will tell you basic frequency.
A Fluke 44 is basic enough although a bit $$!
My favorite meter is the AMPROBE AC/DC 3000 (I think)....it's a clamp-on amperage meter that works wth AC and DC amperages. But also has your basic voltage/resistance checks too.
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
I took a couple to work to see how accurate they were. Believe it or not they were right on the money with our "calibrated" meters.
The downside... They're disposable. The upside... They're disposable. I kills me to even replace the battery. I'm tempted to just chuck it and get an new one out.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Never under estimate the importance of being nice when you don't have to be."
If the battery on your Digital meter fails....it's a paperweight until you replace the battery. But in an analog meter, you don't need a battery for voltage measurements (not sure about current though!)....but you would need a battery for resistance checks!
Also, Digital meters tend to average their readings.....so if you want to see what your RS232 line is doing (if it's sending data and at approx what level) you can connect your analog voltmeter and see the needle bounce, where a digital meter will try to update it's display but usually the transmission is gone by then....so it's not too useful there!
If you have an oscilloscope...well, then you're fine!
Steve
I have half a dozen multimeters. For RF tuning I have a Radio Shack Fet meter with an analog scale. Otherwise, any of my meters seem to do the job. The only other reason to spend more money is if you need capacitance, inductance or temperature reading.
What really counts are the meter leads. Most multimeters have these heavy, nondescript leads with 8 penny nails for test points. Get a good pair of thin leads. I prefer leads with clip on test points. A good set of leads will cost more than the meter.
Bean.
"Wise men know when they're right. The wisest also·know when they're wrong."
BTW, the Harbor Freight sale looks like there are going to be some fairly good deals...
Truly Understand the Fundamentals and the Path will be so much easier...
It even has a backlight now, but you have to push a button and it lights for a 5 seconds. I wish it would stay on. Oh well.
I guess this is a sale price because on the web site it is $9.99.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92020
Bean.
