Pink & javelin
Dear All,
Does someone knows if a class (or example) exists for the Pink module ?
Thanks you.
Eric
Thanks you.
Eric
http://groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/peripheral/web/
regards peter
that uses the statusbits according to discovered results.
····················· //b0 set if network link established
····················· //b1 set if variable has been updated from webpage
····················· //b2 set if Pink ready to send email
····················· //b3 set if last email transmission had error
····················· //b4 set if email has been sent
····················· //b5 set if udp message received
····················· //b6 set if Pink busy (b5-b1 are invalid then)
····················· //b7 not used
regards peter
I'll try your classe next time and provide you feedback.
Eric
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
