Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
activating a relay — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
activating a relay
superi0ro1
1
2006-03-03 05:53
edited 2006-03-03 21:27
in
General Discussion
Is it possible
get an active low or high signal from one of the pin on the micro controller to activate a basic 12 volt relay? or would i have to use a bjt as a switch to activate the relay?
Peter Verkaik
3,956
2006-03-03 06:48
edited 2006-03-03 06:48
You need a bjt. I/O pins can max. sink/source 25mA.
regards peter
Ryan Clarke
738
2006-03-03 21:27
www.parallax.com/detail.asp?product_id=31216
Take a look at the DC-16. Simple serial control of up to 16 (on one DC-16) outputs (via darlington).
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
Sign In
Register
to comment.
regards peter
Ryan
Ryan Clarke
