Surface Mounting questions
I want to eventually dibble and dabble with SMT and trying to do some research on the net with some vague answers as to what tools I would need and the complete process.· I want to do it at a Hobby level so I really don't want to buy elaborate expensive equipment to do so.
THanks,
Chris
-Chris
THanks,
Chris
-Chris
There are several posts about this. But almost all SMT componets can be soldered by hand (except BGA parts and the like).
With a little practice you can even solder fine pitch parts like the SX48.
Are you asking about make baord or assembling boards ?
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
Chris
-Chris
http://www.sparkfun.com/commerce/hdr.php?p=tutorials
...TIGER
Thanks. I've already been there. Actually that's probably where I'm going to get adapters from.
-Chris
-Chris
I also use the iron and tip shown in the video, they are reasonable priced and the staff is friendly and helpful.
·1+1=10
Well, these are not much bigger than a bit of broken pencil lead. I was a bit surprised, but I do plan to use them.
I strongly suspect that the 2-wire components [noparse][[/noparse]resistors and capacitors] are the biggest headache.
Can I use a bit of beeswax to hold them in place? I can easily dissolve it when I clean up the flux with solvent.
Sid
I have the kit from pulsar. All you need is a laser printer and etchant. I have made some boards that use the SX48 (0.5mm lead pitch) and they have worked fine. I'm really happy with this method. Send me·a PM if you have questions about it.
http://www.pulsar.gs/PCB/a_Pages/4_Products/5f_Starter_Kit/Starter_Kit.html
Bean.
"Never under estimate the importance of being nice when you don't have to be."
·1+1=10
Post Edited (Paul Baker) : 2/28/2006 5:08:38 PM GMT
Bean.
That was a good video showing how to solder ICs. In the video, they cheated however. They had the IC already tacked to the board. They did not show how to put a fresh part on a board. What I do is line up the part on the pads to near perfect, and then apply flux to one of the out side pins, and with out touching the pin, put the soldering tip with solder to the tip of the landing (pad or also known as a foot print). The flux will allow the solder to flow all around the lead. the trick is not to use to much solder for tacking. After one pin is tacked, the opposite side of the ic (outside pin) can be tacked in the same manor. there should be two outside pins tacked in a diagonal fashion. This is especially important for fine pitch QFPs.
Liquid flux is the key, no liquid flux, then forget it.
Mike, I do what you describe for chips. But I use a set of fine pitch tweezers for 0402s since they dont have the weight to hold themselves down when soldering, and you'll burn you finger if you try to hold it manually. I too find flux an absolute nessesity when working with SMT, but I dont like paste for hand soldering, there is too much flux in the composition, and I find myself having to frequently reapply paste to get enough solder to make a good joint.
·1+1=10
