Rotate bits — Parallax Forums
Rotate bits
aekloaeklo Posts: 20
edited 2006-02-27 21:49 in BASIC Stamp
I've been trying to figure out a simple method of rotating bits in Stamp Basic, but need some help...
Is there a function or simple way of doing a bit rotationof eg. a byte?
Something like:
B1 VAR Byte
B1 = %00000001
rot(B1) 'gives %10000000
rot(B1) 'gives %01000000
rot(B1) 'gives %00100000
etc.
/Anders
    edited 2006-02-27 19:32
    Check out the ">>" operator:
    B1 VAR Byte
    B1 = %00000001
    B1 = B1<< 7
    B1 = B1 >> 1
    B1 = B1 >> 1
    Tracy Allen
    www.emesystems.com
    edited 2006-02-27 20:05
    Keep in mind that the shift instructions drop of the "end" bit, depending on which way you're shifting.· You can create a subroutine that allows you to catch that bit and put it back into the other side:
    Rotate_Left:
    ··DO WHILE (idx > 0)
    ····carry = temp.BIT7
    ··· temp = temp << 1
    ··· temp.BIT0·= carry
    ··· idx = idx - 1
    · LOOP
    · RETURN
    Rotate_Right:
    ····carry = temp.BIT0
    ··· temp = temp·>> 1
    ··· temp.BIT7·= carry
    ··· idx = idx - 1
    · LOOP
    · RETURN
    In·either case, temp gets rotated, carry is a bit-variable for·storage, and idx is the number of positions to rotate.
    Jon Williams
  • aekloaeklo Posts: 20
    /Anders
