Where do you all get your allen screws?
I'm about to start a new robotics project, and this time I plan on using allen screws instead of the phillips head screws I was using. I couldn't find them at Lowes, so I plan to order them online. Can anyone recommend a site? I would like to get some opinions on the screws before ordering...I don't want to have to change out all the screws on my robot after I find out that they strip easily or something. Thanks.
Brian
There's nothing a good wack with a hammer won't fix
Darn I let the white smoke out again
Socket head cap screws:
#4-40 by 1/4 inch, 430-0017, $3.52 per hundred alloy steel
#4-40 by 1 inch, 510-0021, $5.91 per hundred, stainless
#4 SAE flat washers, 891-2835, $0.88 per hundred
#4-40 lock nuts with nylon inserts, 325-3311, $2.25 per hundred
#4-40 screws are available up to 2 inches long. But they get expensive when length exceeds 1 inch. Example, 2 inch #4-40 screws are $36.75 per hundred.
They sell socket head screws starting at size #0-80, on up.
The local hobby shop charges over a dollar for four screws. One of my typical robots uses 50+ screws, so I buy by the hundred. I find #4-40 meets most of my needs.
I checked smallparts.com, but they are quite expensive (on products, and especially on shipping!). I'm now leaning towards Enco.com. I just can't decide whether to get the "socket head" type or the "button head" type, or both. Also, is alloy steel better or stainless steel? They are roughly the same price, so if there's any difference...
They even have oversized Allen Wrenches so that you don't strip the hole (or the wrench). They are called Hi-Torque L-Key's, and you'll need the 3/32" size for most screws (they have some nice T-Handle ones).
http://www.mcmaster.com/
Bottom right, under Fastening and Sealing.
You'll love how their Web Site helps you narrow your choices, or if you prefer, you can pick directly from the Catalog pages.
Kenny
Try someone that provides screws for Motorcycle Parts in your local Yellow Pages. No listing? Ask a repair shop.
Since motorcycles have a lot of vibration, many people switch over to Allen head screws.
The Phillips need to be set with an impact wrench and get really beat up. At the same time the impact wrench can strip the threads in the aluminum cases.
Often they have the complimentry self locking nuts too.
Try Fastenal· www.fastenal.com
They have stores all over the place. Most stock the small hardware. If they dont stock it they usually get it overnight. You can pick it up at the store and do not have to pay shipping charges.
The drawback is yo uhave to buy them in a bag of 100, but the 4-40 stuff at qty 100 is still cheaper than the hardware store charges for a bag of 5.
Good Luck,
Alan Bradford
Plasma Technologies
www.plasmatechnologies.com
Bill
