What type of eeprom will be used for program storage?
CJCJ Posts: 470
edited 2006-02-26 - 18:08:16 in Propeller 1
I2C, or other?
Size constraints? ex. the bs2 oem will only take a specific one
If it is I2C then adding storage or other chips will be super easy! the bus will be all set up anyway
sorry if this seems fragmented, but that is just how I am, ADHD and all. roll.gif just so excited about the robotics possibilities
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
    edited 2006-02-26 - 17:53:45
    The Propeller uses a 24LC256 at address %000 for its program storage. You could drop additional devices on the same lines (A29 = SDA, A28 = SCL) for your own storage requirements.
    Jon Williams
  • CJCJ Posts: 470
    cool, thanks
