How far can a one-wire device properly operate?
LoopyByteloose
Okay, I realize that SPI and I2C chips are intended to be on the same board as the processor, but One-wire advertises as a 'Micro-lan'.
Recently someone asked me·about using ten temperature gauges on a solar water heater that included pipe in a concrete driveway.· So we are talking meters, not inches.
Can anyone tell me how far a basic unit will go without repeaters or extra boost?
http://pdfserv.maxim-ic.com/en/an/tb1.pdf
and
http://www.maxim-ic.com/appnotes.cfm/appnote_number/148
The first document referenced is "Tech Brief 1 MicroLan Design Guide" and the second is "Application Note 148 Guidelines for Reliable 1-Wire Networks". I have had a chance to read these documents in the past, and the answer to your question seems to be "it depends". Things like what is driving the 1-Wire net, quality of wiring, topology of 1-Wire devices, etc...
Hope this helps and is not obtuse...
Greg York
And I can back. Went to your referals.
The document was a big help as it discusses lengths up to 100 meter.
But generally, there are some limits with any device. A ball park·is nice for starters. I shelved my 1-wire thermometer because it seemed to be of very little additional use. Then I came across comments that said it was superior for distances.
Post Edited (Kramer) : 2/24/2006 5:55:08 AM GMT
