Can the HB-25 motor controller handle this?
www.allelectronics.com/cgi-bin/item/DCM-171/400400/12VDC_GEARHEAD_MOTOR_.html
The description says it draws only 4 amps, but that's with no load. Is there any way to tell by the given information, whether or not the motor is too powerful for the HB-25? Or would I actually have to get a motor and hook it up for my application, then check the current?
Also, it says that it has over voltage, current, and temp protection. Does this mean it's not possible to damage it by these three methods? So if I were to hook up that motor to the controller, it would shut off automatically if the current draw were too much for it?
Post Edited (bulkhead) : 2/22/2006 5:48:08 AM GMT
overhead without any problems. With the 25 Amp overhead the HB-25 is capable of you should be fine. You could always go to
an automotive shop "Pep Boys", "Auto Zone", etc. and look for this exact windshield wiper motor. There should be an indication
as to what the Current rating is on the box, or you could probably measure the resistance across the terminals without too many
raised eyebrows. Tell them you are using it for something other than what it was originally designed for and you just want to test
something first before you buy.
(Current in Amps) = 12V / (Coil Resistance in Ohms)
Beau Schwabe
IC Layout Engineer
Tiger (HB-25 designer)
Beau, can you really estimate stall current draw of a motor by checking the resistance across the motor's terminals? Is this an accurate indicator? Sounds interesting, I'll have to try it.
Oh, by the way, is that a heat sink or cooling fan on the HB-25? It's kind of hard to tell from the picture.
There is a pretty substantial heatsink which is force cooled by a 40mm fan.
...TIGER
And yes checking the motor winding resistance is a good indication of stall current, this is because when a motor is spining, it creates an EMF field in reverse of the motor's winding, this has the effect of increasing the effective resistance seen by the power supply. When the motor is stalled, this back-EMF·doesn't exist, and since you are passing a DC current throught the windings, the windings don't react to the current, therefore only the resistance of the windings is coming into play. If you don't understand this explanation, don't worry, its not nessesary to understand.
·1+1=10
Post Edited (Paul Baker) : 2/22/2006 4:50:45 PM GMT
I have been measuring resistances and estimating load, but I was unsure of what exactly it meant.
I think what you are saying is that figure from my multimeter gives the extreme high end of the load.
"I think what you are saying is that figure from my multimeter gives the extreme high end of the load."
That is correct.
Beau Schwabe
IC Layout Engineer
Does my surge current of greater than the stated 35 amps (for about .040 seconds) prevent me from using the HB-25?· How will the HB-25 react if I try to drive my motor?· Will it shut down and protect itself?· I don't think it will blow the 30 amp fuse.· When you specify the "surge current" are you refering to the peak that I show in my attached file?
Basic stamp Newbie
Post Edited (Hulk) : 3/2/2006 7:18:52 PM GMT
Chris Savage
Parallax Tech Support
csavage@parallax.com
Can you apply any ramping techniques during powerup?
Beau Schwabe
IC Layout Engineer
Don't visit my new website...
So what exactly is this motor of yours and what are you actually going to be doing? You say it goes to 15A when it's running. I assume that is the full load current rating. Are you really running it at full load or is that just the spec?
TIGER
Tiger, I'm encouraged by your comments.· I can only imagine the algorithm that the chip uses to sense an overload.· If it’s looking for an instantaneous current It may shut down.· If it’s just looking for heating I probably won’t have a problem.
I’ve never used PWM to control a motor so I will have to scope it to see how it reacts to my motor.· I will definitely do a soft start (that’s one of the reasons I need the control).· I’m making an electric car for my granddaughter.· If I use only relay control of on/off, it snaps her little neck.
I’ve also added some series resistance as suggested above.· You can see by the waveform attached below that even adding .1 ohm dramatically reduces the peak current.· I don’t know what effect it will have on steady state current when it’s actually running the car with the kid in it.
BTW, The waveforms I’ve posted show unloaded motor current on the bench.· The steady state shows a current about 5 amps higher than the “loaded” current that I measured in the past (with only on/off relay control).· I don’t know why, but suspect lead length or faulty connections may have dropped the current.
Once again, thanks for your comments.· I’m looking forward to adding the HB-25 and will post progress when it arrives.
Basic stamp Newbie
TIGER
I certainly agree with your concern: the rpm can go no where but down when the motor is loaded (no matter what gearing is applied). When it drops, the motor will draw more current and it looks like I would have only 5 amps to add before the HB-25 starts shutting down. I guess I will have to find a different motor in the old parts bin.
Your observation about high power for a kid's car is part of the objective. I'm gearing it for a maximum that will be advanced as she grows older, starting at about 5 mph. We are semi rural and have no side walks so I'm trying to make something she can ride in the yard. There are some some small hills that the commercial kid cars can't handle. I'm making a beefy steel frame to fit under one of those plastic kid car Jeep bodies.
From your comments, it looks like I have some freedom to experiment without fear of actually destroying the HB-25. If I explore the limits (near when it shuts itself down) and and occasionally exceed them (say 10 or 15) times will I harm the part?
BTW, I really appreciate your interaction on this subject. I know your time is valuable, but you share it generously!
Basic stamp Newbie
TIGER
