How do I disable an RFID tag??? ( is it possible to disable the tags we have?)
We purchased the 50 mm Round Tag Stock#: 28142 Category: Accessories-RF... and we are trying to build a mini EMP pulse generator out of a disposable camera - to send an EMP through a copper coil and "Kill" the RFID tags once they are purchased at our fictional cash register... the problem is: we are not sure how much current is needed to disable/kill these tags- or if it is even possible to do so. One of my group members suggested that i write on this forum and ask you guys for any suggestions/info. We have a javelin microcontroller, a Grand Idea Studio RFID Reader Module -Stock#: 28140, and the 50 mm Round Tags. Are we able to send a "code" to disable these tags using our Reader?? ( we have read that it is possible to do so with other models )??? please reply with any suggestions... Thanx.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Chris Savage
Chris Savage
Read them with a second RFID reader at the register as if you are "Nuking" them with an EMP,
then the reader at the door.... hopefully linked to the cash register will still read the RFID but
will know to ignore it.
Beau Schwabe
IC Layout Engineer
If not an EMP, could you set up a layer of foil behind the tag, and use a large static charge (like from a van-de-Graff generator or Telsa coil? Kind of "zap" the tag into oblivion.
This might also have some FCC and/or safety implications.
A more vialble solution might be a different tag that is "writeable". This could then have both a "serial number" and the UPC code writen to it, and then upon read by the cash register be "blanked". This could also allow for tag "re-activiation" in the event of a return.
I don't remember for sure, but I thought you could get tags on this frequency that were 'writeable'. You would be able to read these with the Parallax reader, but you;d need something different to write back (and/or erase) them.
John R.
8 + 8 = 10
It appears that a 1mm thick coil of wire loaded with 100v's from a common camera flash cap was able to disable the 13.56mhz RFID from a short range being just next to it. You can probably disable other frequencies tags by playing with the numbers. That could probably be safe since the range is so short and less likely to damage stuff around nearby, but FCC safety implications will still need to be looked at.
