best possible method for full duplex, high bitrate radio link?
I need some kind of radio link capable of transmitting video one way, and signals the other. I would like to stay away from using two seperate transmitter/receiver pairs for size and power reasons. I mentioned full duplex in the title, and I know that this is not possible with same frequency radio, but as long as the bitrate remains high enough, half duplex is ok. I am aiming for a fairly high range (about 1000' to a mile). I noticed that the xbee pro modules (www.maxstream.net/products/xbee/xbee-pro-oem-rf-module-zigbee.php) are capable of a 1 mile range and the "interface data rate" is 115.2 kbps (I assume that means the data rate at half-duplex). Is that high enough for transmitting black&white video with no sound?
thank you,
Justin W
thank you,
Justin W
If you are in the US, you can can get started with a Technician-class license, which isn't very hard to get.
The "wireless" stuff that doesn't require a license is typically limited in power so that it has a 1,000 foot range (under good conditions).
John R.
8 + 8 = 10
Does anyone know what the bitrate of a small low res (320 lines of res. or so) camera would be? or even what the lowest bitrate of a logitech quickCam is? I suppose if I needed to, I could lower the framerate of the camera in order to lower the bitrate...
You're trying to do 2 things using the same type of data on the same data channel, which will not work....
Video which can include sound AND superimposed text data would be from ROBOT to reciever/controller.
Commands from controller to BOT would be on a seperate channel/frequency.
With the right equipment you can transmit audio/video for quite a long distance.
Some video surveylance transmitter/recievers would work nicely.
A VERY high-gain directional recieving antenna coupled to a good reciever will substantually increase the usable distance.
Sending control data would be even easier, using a high-gain antenna on the BOT with a good tranmitter and highly directional antenna on the controller.
Imagin a video screen with real-time video and a couple of lines of text across the bottom showing heading,
speed, GPS co-ordinates, enviromental data, and bot data (battery charge ect.) And mono sound???
Add in a control channel with audio to BOT's speaker...
Well you get the idea..
Bob N9LVU
Post Edited (Robert Kubichek) : 2/18/2006 10:49:48 PM GMT
Justin,
A few thoughts. The 100mw Maxstream Zigbee module is advertised up to a mile...but frankly, unless you have an absolutely clear line-of-sight (and a dry wind blowing in the right direction) you need to make adjustments. I will buy the 1000' under "normal" conditions where a branch of a tree might be in the way. I am trying to make a Maxstream unit work as a method of harvesting data from some sensors in a marsh. I don't expect more than that, and the transmission path is pretty clear. And I'm only trying to get a few hundred bytes to the data acquisition unit (as it goes by in a boat). Probably not the way to go for video of any kind, as you couldn't stand the retransmissions which will occur; that is good for keeping data straight, but not for a real-time link.
Not to be a wet towel,
Jim
In the end, it seems that it's all about getting the LEDs to blink....
edit: for some reason the second link doesn't work right, so the URL is: www.electronics123.com/s.nl;jsessionid=ac112b2a1f43d859fe07491e45ab9395f6527ba6bb59.e3eSbNyQc3mLe3iKax0KbxqSe6fznA5Pp7ftolbGmkTy?sc=8&category=241&it=A&id=2027
Post Edited (Whelzorn) : 2/19/2006 3:58:13 PM GMT
Cool link and project! He does quote 1000m range with clear line of sight (and the Xbee Pro module) but just remember that line of sight thing...a bot radio 6" off the ground tends to encounter a lot of obstacles to a clear path between sender and receiver. But very cool!
Jim
Howard Gordon
Surveyor Corporation
stuff I'm working on
Post Edited (hgordon) : 3/24/2006 2:38:30 AM GMT
