Quick LED wiring question
Ok, I drew 2 diagrams. The circle is an LED, the rectangle is a resistor. The first circuit has 1 LED with a 100 ohm resistor. The second circuit has 5 LEDs. I don't want to get 5 100 ohm resistors, and put each one on each LED. Is there a way I can just hook up 1 resistor to cover all the LEDs? If so, how do I calculate the value of that 1 resistor?
Thanks.
Thanks.
A quick Google brought up these two resources
http://led.linear1.org/1led.wiz·,
which has a calculator (and schematic wizard) for both series and parallel setups,
and here:
http://www.kpsec.freeuk.com/components/led.htm
which warns against wiring LEDs in parallel as a general design method.
Hope it helps,
Jim
In the end, it seems that it's all about getting the LEDs to blink....
I removed 16 LEDs from one of those LED flashlights. It has only 1 resistor thing. I call it a thing because it is a strange looking resistor, if it is one. It is blue, and has 5 bands instead of 3/4. Measuring the resistance, my MM read 1.6 ohms. The voltage is 4.5V. If my idea is right, then 1 LED needs a 1.6*16 ohm resistor, or 25.6. 4.5V/25.6 ohm is 176mA, which is huge for an LED. Is this right?
current = (Vsource - VLED) / R
Once ON, the forward voltage across the LED (VLED) is·"constant" (at least, it does not vary widely.)··The remaining·voltage that is not across the LED, then, will be across the resistor.
Assuming a 6V source (4 batteries):
current = (6V - 4.5V) / 25
········= 1.5V / 25
······· =·60 mA
Your cheapy flashlight uses one resistor because it costs less to do it that way, not because it's the right thing.· Obviously, if you have some "result" in mind and that's your sole consideration,·you can do this or that or whatever you like.
Post Edited (PJ Allen) : 2/21/2006 3:18:49 AM GMT
But, still,·running multiple LEDs in parallel with a single resistor·is probably not the best approach.· Resistors·are one of the least expensive components you can buy.· I believe it is Jon Williams who says "they are cheap insurance".
Chris I.
kenjj
