Vex Servos
I am a loyal Parallax user, and a strong hobby customer of Parallax's.· However, I like the VEX servos that Radio Shack sells.· They have a great shaft in them.· I picked a set up to try with my Stamp.· However, they do not seem to respond the same way.· In fact, sometimes they would work at different frequencies, and sometimes not.· Anybody know anything about these, who makes them, how I would program them with the stamp?· Appreciate the info.
Again, I state that I am a loyal Parallax customer.· Just like this Servo if I could get it to work.
I've seen a fair amount of discussion on the Vex servos on their discussion forum. It would be worth taking a look. They must have some people who know their servo signal and design better than us at Parallax. I think the link is www.vexrobotics.com.
Good luck -
·1+1=10
Post Edited (Paul Baker) : 1/26/2006 6:26:44 PM GMT
Maybe I was doing something wrong. The link you sent me certainly suggests they are standard 20ms pwm servos.
As for the VEX system, I rejected it out of hand and started with the BOEBOT. My interest was in learning electronics, not building a robot kit. The VEX kit is enclosed, and lots of stuff happens without any explanation of how the actual electronics work. I wanted to learn about NPNs and electrons... And I really have, thanks to the books, the NV articles, and the kind folks in this forum. I am building stuff I never dreamed I could, all of it from scratch at this point.
I just happen to like the heavy duty shaft on the servo. They are the only ones I have found like that. If there were some others, I would consider them, because the VEX add-ons are really priced at a premium. I
I have a VEX kit, so I know something about using this hardware.
My initial VEX build used the R/C interface in their skid-steer system. In this mode, the VEX controller was a pass-through for servo signals. When controlling the robot, we found much difficulty in proportional control, but it was quite easy to have full-on forward or backward. The difficulty resolving the servo's center position demonstrated itself in my attempt to do a "slow right" or "slow left" without a total full reverse/full forward to spin on a dime. We never pulled the servos off of the chassis to test them with a BASIC Stamp.
But, the people on the VEX discussion forum indicate that the signal is a 1-2ms pulse like our servos. If this is true, you can use our Robotics text for example code to control their servos. But, I suspect some difficulty around the center position. One member on the VEX list provided a link to a PWM web site. Just want you to know that the link he provided may pertain to motor control, but not to servo signals.
·1+1=10
Post Edited (Paul Baker) : 1/26/2006 7:18:14 PM GMT
I used to think Parallax components were expensive -- until I looked at every other robotics-type kit out there. Lego Mindstorms come closest at $200 per kit -- but even there you're limited to ONLY three motors and three sensors. And any result looks like Lego, no offense. Nice processor in the brick, though.
I really appreciate the Parallax approach of documenting EVERYTHING, and then assisting with everything. And their processor is simple enough you can get on with interfacing it to hardware, instead of wrestling with assemblers, compilers, debuggers, o'scopes, logic analyzers, board designs, schematics, etc.
Oh, and those symptoms you're pointing out tend to be either grounding issues, or power-supply issues.· Or poor quality in the servos, which haven't been a problem with the Futaba stuff sold by Parallax.
·1+1=10
Post Edited (Paul Baker) : 1/26/2006 9:52:56 PM GMT
VEX kits are quite pricey. Their starter kit includes a reciever unit that has a "programmable microcontroller" within, BUT you can't use it without the cable and software. The cable and software are sold as the "programming kit" and costs $100.
There's no doubt VEX components are more expensive and less reliable (and with less support) than parallax products, but they do introduce a lot of people into robotics. Without Lego or VEX, many people wouldn't be able to make the jump from basically nothing, to programmable stamps. They serve as entry level platforms for beginners to learn from, and without new people entering into this hobby, it would go extinct.
You are probably correct about the spline, I couldn't find a good picture or a·diagram of the servo, and I dont frequent RS's that frequently anymore.
·1+1=10
Post Edited (Paul Baker) : 1/26/2006 11:05:45 PM GMT
Then came Christmas and Radio Shack offered a $50.00 rebate. I· bought one. Two weeks later, Radio Shack inadvertently cut the price by $50.00 and still offered the rebate - a hundred dollars off. I bought another one. In addition to the two kits, I'm a regular at VexLABS and stocked up on hardware. Not for use with just the Vex, but with all robots that I make, including additions to the BOE-Bot.
thier programming guide is a single splash page only describing what it's function is
My programming guide is 59 pages. The documentation for Easy C (Vex's programming language) is well over 100 pages (I purchased the full version).
they don't seem to be paying anyone for technical support (I didnt see any company presence on thier discussion boards
Where are you looking for the Support Forum? Have you tried here:
http://www.vexlabs.com/forum/
is there even a centering adjustment on the servo
Motor Control (centering) is done in software or by programming the Transmitter.
I suspect that Vex was designed as a low cost alternative to the First Robotics kits. If you think Vex is expensive, check out the First stuff:
http://www.ifirobotics.com/
The controller is powerful and worth most of the price of the kit. The Sonar Sensor is a Devantech SRF-04. The Wheels are awesome, as are the Tank Treads and·Sprocket and Chain Kit. I don't know who manufactures the Servos, but their quality is no worse than the Futaba's that Parallax uses.
As to the original question, I assume that when you say Servo, you are talking about the Vex Motor, which is a continuous rotation servo. Whether you are or not, I can use my Vex Servos, continuous and regular, with Parallax servo code. ServoTest.bs2 from What's a Microcontroller works just fine with my Vex regular Servos. The Boe-Bot code works just fine with my Vex motors.
Kenny
Kenny Gardner
GAP Development Company
http://www.gapdev.com/
' {$STAMP BS2} ' {$PBASIC 2.5} index VAR Byte LOW 0 FOR index = 500 TO 1000 PULSOUT 0, index PAUSE 20 NEXT' {$STAMP BS2} ' {$PBASIC 2.5} index VAR Byte HIGH 0 FOR index = 500 TO 1000 PULSOUT 0, index PAUSE 20 NEXTYou might also try changing the PAUSE value from 0 through 100 to see if maybe the refresh rate of pulses is different.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Having not purchased the kit, I do not have access to any printed materials. The documentation availible online, which looks as though its the "official" documentation, has a single page for the programming.
No I didnt see the forums, the only link I could find on the website http://www.vexrobotics.com·was a link to thier message board, which only has a hundred or so posts and none which seem to be from company employees, I am curious why they would maintain a message board and a forums with no apparent connection between the two.
Nifty, but that means you have to buy the entire system to just center a servo, a very "Mac'ish" thing to do. (Not a knock on Macs themselves, just Apple's historical business practices).
That may be the case, but it doesn't mean it a good value. I could come out with a clone of a Toyota Matrix for $50K and say "but its much cheaper that a Farrari, so its a deal".
Look Im not trying to knock your choice, Im sure in many respects its a great system. But, being a Parallax customer, Ive come to expect a lot of value for a reasonable price and customer support that will bend over backwards to help, I just dont see Vex meeting that high level of expectation.
·1+1=10
·1+1=10
Post Edited (Paul Baker) : 1/27/2006 5:56:17 AM GMT
On standard RC equipement, they have worked with all RX outputs I have hooked them to, and with servo testers. They may or may not have a slightly higher minimum operating voltage than some servos (something to look for, especially if you are running a 3.3v system). It likes, as I recall, a minimum of 4.8v, and is 9v (or greater) tolerant.
The square shaft and clutch are interesting, and mounting is a tad different than other servos. The servos and motors, at $19.95 each, are not particularly expensive relative to servos of similar specifications, and are sold separately with a spare set of gears.
There is a sidebar in the December, 2005, issue of Servo Magazine with more info (olook under Radio Contro model Warship Combat.
Hope this proves helpful.
Wreno
