enable the reader — Parallax Forums
enable the reader
coolbebecoolbebe Posts: 9
edited 2006-02-16 19:29 in General Discussion
How can i enable the reader? The reader enters its active state when the Enable pin is pulled low. would this work?
CPU.writePin(CPU.pins[noparse][[/noparse]0],false);
  • Peter VerkaikPeter Verkaik Posts: 3,956
    Yes,
    You can also use
    CPU.writePin(CPU.pin0,false);
    which takes less code because CPU.pin0 is a constant
    regards peter
