order,routing,configuration using microcontrollers
When using a Microcontroller how do i change the order,routing,configurations ?
examples: series circuit
Resistor#1 is 1K
Resistor#2 is 1.5K
Resistor#3 is 4.7K
How do i change the Order of these 3 resistors to put them in different configurations?
What instruction would do this please so i can change the order and configurations
Examples#2
How do i change a Series circuit of R1 R2 R3 into a Parallel circuit to have R1,R2,R3 in parallel from the microcontroller
instructions changing the order of the path ways from a series circuit or a parallel circuit?
Which instruction code would do this please?
Example#3
On the board is a Filter eq tone stack with resistors and capacitors how many inputs would i need for the microcontroller so i can change the order and configuration of the Filter eq stack to convert the same resistors and capacitors components used to make a different filter design#2 tone stack? each resistor and capacitor would need a I/O port on the microcontroller or can i use a multiplexer or encoder to use just one Port on the microcontroller chip?
Using the microcontroller to convert Filter design#1 into filter design#2 how do i do this please which instructions and how the ports on the microcontroller would do this please?
Resistor#1 is 1K
Resistor#2 is 1.5K
Resistor#3 is 4.7K
Examples#2
Example#3
It is very easy. You simply lay a $50 bill to your teacher/prof's desk, then nicely ask him/her for the answers.
It worked for me [noparse];)[/noparse]
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
In regard to the two examples.
If you learn some electric theory, you can answer the questions yourself.
I do not know what country you are from, but I bet they have this thing called a library. Go to said library and check out one or more books on BASIC Electronics/Electricity. This will answer most if not all of your current questions on, as you call it order,routing,configurations .
Charlie
Chris Savage
Parallax Tech Support
csavage@parallax.com
Jon Williams
