Is there an ADC0838 class?
Hi javelin programmers. This is my first post. I just ran a program using the ADC0831 class and it worked fine. I also have the ADC0838 chip that is suppose to handle 4 analog inputs. Is there a special class (or subclass)·for this chip that is available or perhaps can the same class be used with an extra or adjusted param?
thanks, John
thanks, John
and adapt it to the ADC8038.
You would need to introduce a channel parameter (for channels 0-3)
regards peter
regards peter
