16 LED Bargraph Display Using BS2 — Parallax Forums
Lee_SpeakmanLee_Speakman Posts: 32
edited 2006-02-14 19:41 in General Discussion
As some of you may know im designing a digital tachometer for a car. Id like to have a bargraph display, that will increment as your engine revs increase. I only want to use 4 output pins.
So far ive thought of using a BCD 1-10 chip and cascade them.·The only problem with this is only one LED will be on a time, wherease I want to have it looking like a bargraph, does anyone know of a specialist chip that will do such a task?
I could also use some kind of counter, that will increment by one ever time it recieves a pulse on a pin, and decrements by one if a pulse is recieved on another pin. This would save me 2 more pins. is there a chip avaliable for this too?
I could easily design either of the above drivers, problem is, its going to take multiple chips to do it, and im concerned with PCB space.
Thanks in advance:
Lee S
  • David BDavid B Posts: 593
    edited 2006-02-11 15:45
    The LM3916 might do what you're looking for.
    David
    edited 2006-02-11 16:23
    You could always use a 16-bit shift register....
    datasheet: (16-Bit)
    http://www.fairchildsemi.com/ds/74/74F675A.pdf
    ..This would only require 3 I/O pins. This is also
    be comparable to using two 8-bit shift registers.
    http://www.parallax.com/detail.asp?product_id=602-00009
    datasheet: (8-Bit)
    http://www.semiconductors.philips.com/acrobat_download/datasheets/74HC_HCT595_4.pdf
    Beau Schwabe
    IC Layout Engineer
  • pjvpjv Posts: 1,903
    edited 2006-02-11 18:08
    Hi Lee;
    So why not use a simply connected SX running at 4 Mhz to drive the 10 bar graph LEDs, and use a serial pin for communications with whatever is generating the bar "signal".
    This would be a way to make your own "specialist chip", and it only uses one (communications) pin. Alternately, of course, you could choose not to do communications, and use 4 pins encoded with the bar info. And to boot, it's all done with a single chip.
    Cheers,
    Peter (pjv)
    edited 2006-02-11 18:24
    Your right Peter, somehow I was thinking that he wanted a 16 led bargraph.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-02-11 19:44
    Hi Beau;
    Evenso, with a simple SX20 there are enough pins for 16 leds plus 4 for data.
    Cheers,
    Peter (pjv)
  • Lee_SpeakmanLee_Speakman Posts: 32
    edited 2006-02-11 22:07
    Hi guys,ive considered the LM3916, but it is voltage controlled, and as far as im aware there is no way to vary the voltage of output pins. I could interface it with a frequency to voltage converter such as the LM2917 and use the freq out command, however Its just making things more complecated. I take it the SX is another parallax product? I really would like to use more 'off the shelf' products as in England buying a BS2 I wont have much change from $70. For some reason I never even considered a shift register - I think the expression 'Cant See the Forest for the Tree's' applies here! Thanks everyone will let you know how I get on!
    edited 2006-02-11 22:11
    On a Digital Dashboard mod I did to a Pontiac Grand Prix some years ago I used the LM3914 with a F-V converter for the analog bar graph section.· On the Stamp you could use the PWM output depending on how much time could be devocted to "re-freshing" that pin, but the buffer circuit could be configured as a sample & hold using an op-amp.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
    edited 2006-02-11 22:27
    So depending on how many LED's I want on, I can use the PWM command to vary the 'voltage' from the F-V comverter? I seem to remeber the PWM command doesnt produce a constant frequency and the duty cycle is a bit random over small spaces of time. Would it be able to control the F-V converteraccuratly enough?
    edited 2006-02-11 22:57
    Lee,
    ·· No, the F-V and BS2 PWM use are mutually exclusive.· You should use one or the other.
    Chris Savage
    edited 2006-02-12 20:25
    Hey gents ive found a shift register in my box of bits and id like to try this code out that I found in one of the parallax publications. Probloem is, it wont even tokenize. It has problems on the first line "Clock PIN 0" It says expected : or end of line.
    Im fairly new to Basic stamp and PBASIC so i dont know why this code is wrong, can anyone point me in the right direction?
    ' {$STAMP BS2}
    Clock PIN 0 ' shift clock (74HC595.11)
    SerData PIN 1 ' serial data (74HC595.14)
    Latch PIN 2 ' output latch (74HC595.12)
    DelayTime CON 100
    pattern VAR Byte ' zig-zag pattern
    Reset:
    LOW Latch ' make output and low
    pattern = %00000001
    Main:
    DO
    GOSUB Out_595 ' put pattern on 74x595
    PAUSE DelayTime ' hold
    pattern = pattern << 1 ' shift pattern left
    LOOP UNTIL (pattern = %10000000)
    DO
    GOSUB Out_595
    PAUSE DelayTime
    pattern = pattern >> 1 ' shift pattern right
    LOOP UNTIL (pattern = %00000001)
    GOTO Main
    Out_595:
    SHIFTOUT SerData, Clock, MSBFIRST, [noparse][[/noparse]pattern] ' send pattern to '595
    PULSOUT Latch, 5 ' latch outputs
    RETURN
    edited 2006-02-12 20:33
    I think ive sorted the first 3 lines out by changing PIN to CON. Im having the same error messatges pop up with the LOOP UNTIL statements now.
    edited 2006-02-12 20:53
    Sorry gents all fixed and working a treat. To many beers i think!
    edited 2006-02-12 20:58
    Lee you need the PBASIC 2.5 directive in your code for the PIN statement to work.
    Chris Savage
  • mediaprefectmediaprefect Posts: 31
    Lee,
    "Hi guys,ive considered the LM3916, but it is voltage controlled, and as far as im aware there is no way to vary the voltage of output pins."
    How about a single pin solution? PWM out on one pin through a diode into an RC filter, charging a cap and bleading off the charge with the resistor. Take that voltage into the LM3916 and drive your LED display. Adjust your RC time constant to suit you application.
    Rick
