16 LED Bargraph Display Using BS2
As some of you may know im designing a digital tachometer for a car. Id like to have a bargraph display, that will increment as your engine revs increase. I only want to use 4 output pins.
So far ive thought of using a BCD 1-10 chip and cascade them.·The only problem with this is only one LED will be on a time, wherease I want to have it looking like a bargraph, does anyone know of a specialist chip that will do such a task?
I could also use some kind of counter, that will increment by one ever time it recieves a pulse on a pin, and decrements by one if a pulse is recieved on another pin. This would save me 2 more pins. is there a chip avaliable for this too?
I could easily design either of the above drivers, problem is, its going to take multiple chips to do it, and im concerned with PCB space.
Thanks in advance:
Lee S
Thanks in advance:
Lee S
David
datasheet: (16-Bit)
http://www.fairchildsemi.com/ds/74/74F675A.pdf
..This would only require 3 I/O pins. This is also
be comparable to using two 8-bit shift registers.
http://www.parallax.com/detail.asp?product_id=602-00009
datasheet: (8-Bit)
http://www.semiconductors.philips.com/acrobat_download/datasheets/74HC_HCT595_4.pdf
Beau Schwabe
IC Layout Engineer
So why not use a simply connected SX running at 4 Mhz to drive the 10 bar graph LEDs, and use a serial pin for communications with whatever is generating the bar "signal".
This would be a way to make your own "specialist chip", and it only uses one (communications) pin. Alternately, of course, you could choose not to do communications, and use 4 pins encoded with the bar info. And to boot, it's all done with a single chip.
Cheers,
Peter (pjv)
Beau Schwabe
IC Layout Engineer
Evenso, with a simple SX20 there are enough pins for 16 leds plus 4 for data.
Cheers,
Peter (pjv)
Chris Savage
Parallax Tech Support
csavage@parallax.com
·· No, the F-V and BS2 PWM use are mutually exclusive.· You should use one or the other.
Chris Savage
Im fairly new to Basic stamp and PBASIC so i dont know why this code is wrong, can anyone point me in the right direction?
' {$STAMP BS2}
Clock PIN 0 ' shift clock (74HC595.11)
SerData PIN 1 ' serial data (74HC595.14)
Latch PIN 2 ' output latch (74HC595.12)
DelayTime CON 100
pattern VAR Byte ' zig-zag pattern
Reset:
LOW Latch ' make output and low
pattern = %00000001
Main:
DO
GOSUB Out_595 ' put pattern on 74x595
PAUSE DelayTime ' hold
pattern = pattern << 1 ' shift pattern left
LOOP UNTIL (pattern = %10000000)
DO
GOSUB Out_595
PAUSE DelayTime
pattern = pattern >> 1 ' shift pattern right
LOOP UNTIL (pattern = %00000001)
GOTO Main
Out_595:
SHIFTOUT SerData, Clock, MSBFIRST, [noparse][[/noparse]pattern] ' send pattern to '595
PULSOUT Latch, 5 ' latch outputs
RETURN
Chris Savage
"Hi guys,ive considered the LM3916, but it is voltage controlled, and as far as im aware there is no way to vary the voltage of output pins."
How about a single pin solution? PWM out on one pin through a diode into an RC filter, charging a cap and bleading off the charge with the resistor. Take that voltage into the LM3916 and drive your LED display. Adjust your RC time constant to suit you application.
Rick
