Sumobot an IR eyes
Hello,
This week I received my first SumoBot and got it up and running
. I have the following issue: the detection of objects with the IR Leds is not so reliable. It works fine if the robot is in mode 1 (no power to the servo) and if I press and hold the leds and receivers for a while. When I relese it on the floor, There is often an eye that does not detect anything.
How can I attach these LEDs and receivers better?
Thx
. I have the following issue: the detection of objects with the IR Leds is not so reliable. It works fine if the robot is in mode 1 (no power to the servo) and if I press and hold the leds and receivers for a while. When I relese it on the floor, There is often an eye that does not detect anything.How can I attach these LEDs and receivers better?
Thx
Post Edited (Andy Lindsay (Parallax)) : 2/9/2006 11:35:30 PM GMT
90% of electrical failures are in the connections. Breadboard is fine to get started, but it never has been intended for long-term reliable use. Things fall apart or wiggle loose.
