Byte(2) variable and UNKNOWN COMMAND: LET
Hi everyone-
I'm working on some parsing routines in SX/B and have run into a problem that I've been pulling my hair out for most of the day. This is my first experience programming with SX/B and I've been making some pretty good progress until this issue. I'm using SX-Key v3.10 and SXB 1.42.01.
Here is the relevant, problematic code:
The code should take a string like "00033.4" and convert it to two bytes: $014E (which is 334 in decimal). I'm getting the following error:
Error 16, Pass 1, UNKNOWN COMMAND: "LET"
If I change tmpWord to a single Byte, the program will compile fine, but will overflow the variable for any string longer than "00025.5". Is SXB not designed to handle words (16-bit) variables or am I just doing something else wrong? Actually, the program SHOULD be using three bytes to handle any string up to "99999.9", but I'm having enough trouble with 2 bytes at the moment.
Any help would be appreciated! [noparse]:)[/noparse]
Joe
rcvBuf VAR Byte(8)
tmpWord VAR Byte(2)
tmpWord = 0
FOR idx1 = 0 TO 6
IF rcvBuf(idx1) <> "." THEN
rcvBuf(idx1) = rcvBuf(idx1) - "0"
tmpWord = tmpWord * 10
tmpWord = tmpWord + rcvBuf(idx1)
ENDIF
NEXT
Joe
You are correct. Currently SX/B only works with byte variables. I have written some routines to do WORD math. I'll see if I can dig them up and I'll post their location for you.
[noparse][[/noparse]edit]
Okay found it. It's at this post, go about 3/4 of the way down and you'll see MATH16.SXB download that.
Feel free to just cut-n-paste the WORD_MULT_BYTE and the WORD_ADD_BYTE routines.
http://forums.parallax.com/showthread.php?p=559038
[noparse][[/noparse]EDIT AGAIN]
Oops, found a bug in the WORD_MULT_BYTE routine. Joe if you already downloaded it, please get it again. I fixed it and reposted it.
Joe here is the code I used to test it...
Start: PUT rcvBuf, "00012345" ' FOR TESTING ONLY tmpWord = 0 FOR idx1 = 0 TO 6 IF rcvBuf(idx1) <> "." THEN rcvBuf(idx1) = rcvBuf(idx1) - "0" WORD_MULT_BYTE tmpWord, 10 ' tmpWord = tmpWord * 10 WORD_ADD_BYTE tmpWord, rcvBuf(idx1) ' tmpWord = tmpWord + rcvBuf(idx1) ENDIF NEXTBean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
Post Edited (Bean (Hitt Consulting)) : 2/9/2006 1:35:08 AM GMT
The function you posted should work well with a string up to "6553.5", which would give us $FFFF. Now, this may be too much to ask (as you've already solved my initial problem), but if I had the string "99999.9", the maximum possible in the field I'm receiving, that would require a three-byte value: $F423F (well, $0F423F). I suppose I'd need to put together routines that work with LONG variables (32-bit) now instead of WORD. Could I somehow make use of your 16-bit functions?
Joe
