SX-Key failing with added subcircuit load?
(New Subject)
Hey folks, here is my setup: I have the SX28 with two ports connected in output mode to (2) mosfet push-pull driver subcircuits toggling 18 volts from ABOVE my LM2394 voltage regulator fed by 18 volts DC (1 amp). When I had one push-pull subcircuit, the set up worked fine. When I added # 2, the SX Key programs the chip then just before or at the beginning of running I get an error "Cannot find SX Key on com 3". I assume I am running out of power - is the SX "browing out"? What is happening and how to reconcile.
MR. BBAL
MR. BBAL
Something like 10uF to 100uF.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
Try switching the two sub-circuits, does the error now appear when #1 is attached?
Nate
Adding the capacitor didn't fix the problem. It appears that when 1 sub circuit is attached, sometimes the SX Key fails but when both subcircuits are attached the key fails all the time. What do I do? Tryt he system without the SX Key (just crystal).
BBAL
Jon Williams
Seriously, what do you think about increasing the inductor value on the LM? I've got the typical connection at 330uh on the datasheet...www.national.com/ds/LM/LM2574.pdf. Or would u - increase the wallwart voltage or amperage feeding the LM?
4K7 pulldown resistors to ground on the appropriate SX pins would discourage this behaviour.
(Post a schematic, or specs on the drivers, for better advice)
Steve
Do you have a handy spot that you could insert an ammeter and see what the real deal is? With the data on the current draw, you can really see what's happening with the supply. Just a thought,
Jim
In the end, it seems that it's all about getting the LEDs to blink....
