TLC2543 self test, BS2p40
Hello gang,
I had a PCB made that uses BS2, an op-amp and a TLC2543 A/D.· I tested the circuit using a BS2 and BOE before ordering the PCB.· Now, of course, the PCB arrives and I get all 0's back from the TCL2543.· Does anyone know what the 'self test' procedure looks like for a TCL2543 and what BS2 code would look like to trigger it?· I have looked at the circuit laid out on the PCB, and can't locate any issues. A self test procedure would sure help me isolate if the issue is in the PCB design, the PCB fab, a component, etc.
Anyone?· Tracy?· Help!
Tracy Allen
www.emesystems.com
Thanks for the advice.· I did indeed have I/O crossed, and all seems to be working now.
But just for my own information: The TLC2543 whitepaper talks about a self test mode.· Have you ever invoked this from a BS2?
Regards!
The test inputs are internal connections to Vref-, Vref+ and (Vref+ - Vref-)/2. You convert those voltages in the normal manner by sending a command request for the test channels 13, 12 or 11. I don't find them very useful, except I address channel 11 at power up or after wakeup, to force a dummy throw-away conversion, so that the chip is properly initialized.
Tracy Allen
www.emesystems.com
