Line ends?!
I'm having trouble sending commands to my GPS.
If I use HyperTerminal (AND use "Send line ends with line feeds" in the ASCII setup) to send the commands to the GPS it works. I get VTG values back.
But I can´t get it to work when I send the same command with the Javelin.
How do I send the same type of "line end" as the terminal program does at the end of the command??
Regards
Fredric
Regards
Fredric
or use \r\n inside a string like "command\r\n".
regards peter
