usb servo controller
I just got my new servo controler and I'm having some problems.··I've installed the drivers·and it is comunicating on a virtual comm port.· The lights glow red·with usb connection and·when I adjust the PCSI software controls the green light blinks. The servos, unfortunatly, will not move.· I'm using a 4 pack battery(aa) to power the servos.· On more thing, when I click 'Get Version' the window reads 'Version ...'.· Any help even if its bad news would be appreciated.
jim
jim
·· What position is the jumper next to the reset switch in?· Is should be open.· If it is, try to control your servos as if they were addressed 16-31 to see if that works.
Chris Savage
Parallax Tech Support
csavage@parallax.com
jim
Chris Savage
thanks
jim
I would like to use as many as 16 of these servos. Is there an amperage limit for the controller? I would like to use a simple plug in transformer but I do not want to 'over do it'.
Dimension : 40.6mm*19.8mm*37.8mm
Weight : 1.78oz (48g)
Operating Speed (4.8V no load) : 0.17sec / 60 degrees
Operating Speed (6.0V no load) : 0.13sec / 60 degrees
Stall Torque (4.8V) : (13kg/cm)
Stall Torque (6.0V) : (15kg/cm)
Temperature Range : -30 to +60 Degree C
Dead Band Width : 4ms
Operation Voltage : 3.5 - 8.4Volts
The major amount of current goes through the Power and Ground connections. The Control connection (the one the controller is connected to) takes very little current. So, the controller doesn't have an amperage limit, because the amperage should be going directly from the battery to the Power line.
OK, but you STILL need to know the current the Servo's pull on the Power line when fully loaded. Which you don't have the spec for yet.
The only reference I've been able to come up with show 8 mA 'idle' and 350 mA when moving with no-load. Loaded currents can be much higer -- 1 amp per servo? Testing this would be the best way of finding out.
For 16 of them, you may want separate wall-wart supplies for each 'clump' of 4 servo's. Or a single 20 Amp supply. Make sure all the GROUND wires are connected together some-place, but the Power should be routed point-to-point.
Chris Savage
