Old program question
Buck Rogers
Hello!
Sometime ago I retreived from either the N&V site or even around Parallax itself a series of example Stamp programs that will talk to LCD displays. Two are for the Stamp1, and one is for the Stamp2. All three use the parallel method rather then the serial method. However they were written for 16x1 displays. All I have here are 16x2 and 16x4 displays.
Would the program work with a 16x2? I am presenting it via the Code function here:
And there it is. Also I've got a question regarding the references to how the stamp is connected. The RS pin on the LCD is going to Pin4 on the stamp. But so is DB7 pin on the LCD. Am I missing something here? Also I haven't tried the code yet. I am just searching for advice first.
Buck Rogers
www.gregg.levine.name
' Listing 1
' Nuts & Volts: Stamp Applications, September 1997
' -----[noparse][[/noparse] Title ]-----------------------------------------------------------
' File...... LCDDEMO1.BAS
' Purpose... Stamp 1 -> LCD (4-bit interface)
' Author.... Jon Williams
' E-mail.... [url=mailto:jonwms@aol.com]jonwms@aol.com[/url]
' Started... 16 JUL 1994
' Updated... 25 JUL 1997
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' This program demonstrates the various standard features of a 1x16 LCD
' display that uses the Hitachi HD44780 controller.
' LCD Connections:
' LCD (Function) Stamp
' pin 1 Vss Gnd
' pin 2 Vdd +5
' pin 3 Vo Gnd (or wiper of 10K pot)
' pin 4 RS Pin 4
' pin 5 R/W Gnd
' pin 6 E Pin 5
' pin 7 DB0 Gnd
' pin 8 DB1 Gnd
' pin 9 DB2 Gnd
' pin 10 DB3 Gnd
' pin 11 DB4 Pin 0
' pin 12 DB5 Pin 1
' pin 13 DB6 Pin 2
' pin 14 DB7 Pin 4
' -----[noparse][[/noparse] Revision History ]------------------------------------------------
' 16 JUL 94 : Version 1.0 - compilation of code from last 3 months
' 08 AUG 96 : Trimmed code to save space -- no performance changes!
' 25 JUL 97 : Updated for Nuts & Volts
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
SYMBOL RS = 4 ' Register Select (1 = char)
SYMBOL E = 5 ' LCD enable pin (1 = enabled)
' LCD control characters
SYMBOL ClrLCD = $01 ' clear the LCD
SYMBOL CrsrHm = $02 ' move cursor to home position
SYMBOL CrsrLf = $10 ' move cursor left
SYMBOL CrsrRt = $14 ' move cursor right
SYMBOL DispLf = $18 ' shift displayed chars left
SYMBOL DispRt = $1C ' shift displayed chars right
SYMBOL DDRam = $80 ' Display Data RAM control
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
SYMBOL char = B1 ' character sent to LCD
SYMBOL index = B2 ' loop counter
' -----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
EEPROM ("THE BASIC STAMP!") ' preload EEPROM with message
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Init: Dirs = %00111111 ' set 0-5 as outputs
Pins = %00000000 ' clear the pins
' Initialize the LCD (Hitachi HD44780 controller)
LCDini: PAUSE 500 ' let the LCD settle
Pins = %0011 ' 8-bit mode
PULSOUT E, 1
PAUSE 5
PULSOUT E, 1
PULSOUT E, 1
Pins = %0010 ' 4-bit mode
PULSOUT E, 1
char = %00001100 ' disp on, crsr off, blink off
GOSUB LCDcmd
char = %00000110 ' inc crsr, no disp shift
GOSUB LCDcmd
char = ClrLCD
GOSUB LCDcmd
' -----[noparse][[/noparse] Main Code ]-------------------------------------------------------
Start: FOR index = 0 TO 15
READ index, char ' get character from EEPROM
GOSUB LCDwr ' write it
PAUSE 50 ' delay between chars
NEXT
PAUSE 2000 ' wait 2 seconds
char = CrsrHm ' move the cursor home
GOSUB LCDcmd
char = %00001110 ' turn the cursor on
GOSUB LCDcmd
PAUSE 500
char = CrsrRt
FOR index = 1 TO 15 ' move the cursor accross display
GOSUB LCDcmd
PAUSE 100
NEXT
FOR index = 14 TO 0 STEP -1 ' go backward by moving to
char = DDRam + index ' a specific address
GOSUB LCDcmd
PAUSE 100
NEXT
char = %00001101 ' cursor off, blink on
GOSUB LCDcmd
PAUSE 2000
char = %00001100 ' blink off
GOSUB LCDcmd
FOR index = 1 TO 10 ' flash display
char = char ^ %00000100 ' toggle display bit
GOSUB LCDcmd
PAUSE 250
NEXT
PAUSE 1000
FOR index = 1 TO 16 ' shift display
char = DispRt
GOSUB LCDcmd
PAUSE 100
NEXT
PAUSE 1000
FOR index = 1 TO 16 ' shift display back
char = DispLf
GOSUB LCDcmd
PAUSE 100
NEXT
PAUSE 1000
char = ClrLCD ' clear the LCD
GOSUB LCDcmd
PAUSE 500
GOTO Start ' do it all over
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
' Send command to the LCD
' Load char with command value, then call
' Clear the LCD............. $01, %00000001
' Home the cursor........... $02, %00000010
' Display control........... (see below)
' Entry mode................ (see below)
' Cursor left............... $10, %00010000
' Cursor right.............. $14, %00010100
' Scroll display left....... $18, %00011000
' Scroll display right...... $1C, %00011100
' Set CG RAM address........ %01aaaaaa (Character Generator)
' Set DD RAM address........ %1aaaaaaa (Display Data)
' Display control byte:
' % 0 0 0 0 1 D C B
' | | +-- blink character under cursor (1=blink)
' | +---- cursor on/off (1=on)
' +------ display on/off (1=on)
' Entry mode byte:
' % 0 0 0 0 0 1 X S
' | +-- shift display (S=1), left (X=1), right (X=0)
' +---- cursor move: right (X=1), left (X=0)
LCDcmd: LOW RS ' enter command mode
' then write the character
' Write ASCII char to LCD
LCDwr: Pins = Pins & %11010000 ' save 7, 6 and RS; clear bus
Pins = char / 16 | Pins ' output high nibble
PULSOUT E, 1 ' strobe the Enable line
Pins = char & $0F | Pins ' output low nibble
PULSOUT E, 1
HIGH RS ' return to character mode
RETURN
Buck Rogers
Jon Williams
Jon Williams
·· Since we sell a Parallel LCD still you can find the Hitachi Datasheet at the bottom of our product page.
http://www.parallax.com/detail.asp?product_id=603-00006
Chris Savage
Parallax Tech Support
csavage@parallax.com
Jon Williams
Chris Savage
I had a 2x12 LCD I just could not get to work...
I hooked it up according to the diagram and used the code form the parallax webiste and it worked on the first try...
Thanks for the tip...
/Bamse
Chris Savage
