BS1 Support for non-Windows
Mike Green
I've asked this before, but Jon's post on a VB interface for the BS1 DEBUG output got me going again. How about some kind of BS1 support for the Macintosh? I know the compiler you're using was written in assembler and is included in the new Stamp Editor through a very effective "fudge", but, with your new BS1USB and the Prop-1, there's new incentive for wider support. I can run the Stamp Editor either with Virtual PC or Guest PC on a Mac, but downloading is very "iffy" at best .. probably due to timing problems with the emulation. If you can't afford the resources to recode the compiler, how about making the source and interpreter description available through a non-disclosure agreement for someone else to try?
Jon Williams
