Circuit board - methods to make it
Hi All ,· I haven´t looked around so if this an repetead post I apologize.
I trying a method of building Circuit Boards that uses UV light ( I never had used it before, always on hand write ) . And it seems very tricky to get uniform results.
I´m wondering what kind of methods are you all using for building your own Quality Boards ?
( I´m trying a product called PRP and PDN from Electrolube )
Thanks in advance
Ricardo Amaral
Thanks in advance
Ricardo Amaral
1. Do your art work (I used Microsoft's Paint Brush...which took a little set up time to get the right pad spacing between the legs of the IC's voltage regulators and other components) This is .1 inch spacing on IC's.· Print out your pads that make up the various IC's in your project and test by placing the IC or it's socket on the paper to see if the feet line up.· When you get the spacing just right, go to properties and save the attributes of that drawing size so you can always return and have it right.· Connect the pads with lines or traces to make your circuit.
2. Follow the instructions that comes with the Press and Peel as far as getting the art work from the printed paper to there special paper.· Requires a copy machine that uses toner fluid.· Most print shops have this kind of printer.· Usually, it is a big one that stands 3 to 4 feet off the floor and requires some help from an assistant in the store.· Lots and lots of buttons.·Set the contrast control to one position darker then the standard middle position.
3. REALLY clean your precut copper board with a dry 3M scrubbie.· Really clean means really clean and don't touch the copper after. Cut out the artwork with sissors from the press and peel (same size as the artwork) and...important...blow all dust off copper surface and the press and peel artwork. DO NOT WASH!
4. Place the artwork as directed down on the copper...don't touch the artwork or the copper with your fingers.· Hold by the edge.
5.· Now here is the secret where people that use this process have a problem.· A hot iron is needed, I set it at the "Cotton" setting AND I carefully place a clean dry (one layer) paper towel over the complete assambly.· Be careful not to move the artwork on the copper when placing the paper towel.
6. With the hot iron, start to rub the paper towel in a cornor or along one side to "lock" the artwork to the copper.· Evendually, go all over the towel portion that covers the artwork/board.· Do this for several minutes, always moving the iron. Do not rub the iron on the blue acitate of the Press and peel directly, or you will make a big mess.· Always keep a portion of the paper towel between the iron and the artwork.
7. The next secret is....cold water from the facuet.· Holding the copper/artwork assambly on edge under the cold water, take a tooth pick or sharp impliment and just start to seperate the blue artwork from the copper.· When the water finally gets between the artwork and the copper, it will release and fall in the sink.
8. Thats it...inspect the board for missing traces and touch up if necessary with a fine tip sharpee pin.· The ink in the sharpee is also resistant to the etching acid.· Only once in a while do I have to touch up.· Usually, a touch up is caused by a single piece of lint or dust between the artwork acitate and the copper.· The board and the artwork on it may be dried with the paper towel·and is hard to the touch.· Ready for etching.
9.· You will need to drill the various small holes in you pads for the thru the hole parts.· And a drill bit of 1/16 is way to big.· The company above sell small drill bits that can be used in a dremial tool.
The following is a sample of artwork using Microsoft's Paint Brush.
Hope this helps...using the Paint Brush program will take some expermenting to get the pad spacing right on different IC's.
There are a few steps that are necessary to "calibrate" your environment.
First get a scrap piece of your Photosensitive board and mark it off like a ruler
every 1/2 inch or so. Cover ALL but one section of the scrap piece and expose
the scrap to your light source for 5 minutes. Move the scrap piece so that the
next section is exposed. Repeat this every 5 minutes until you have a record
of at least 30 minutes. Now place the scrap piece of Photosensitive board into
your etching solution. Check this every 5 min until your scrap piece is etched.
Note: You will (should) be able to see an obvious "sweet spot" where the copper
is completely gone, vs. still present. Now, as long as your setup does not change,
you have the correct exposure times that should work on any of your boards.
Now, as far as transferring the artwork to the Photo sensitive board. ....There are
a few methods. Ideally you could use a "flat bed printer" and print directly to the
board but these are hard to come by. My preferred method if I'm doing this myself
is to print my artwork to Paper on a x2 scale. Then take my printout to a copy shop
and have a transparency made with a 50% image reduction.
Once I have a nice transparency, I can place this directly over the Photo sensitive
board. For better yield I place a piece of glass over the transparency. So it looks
something like this....
Beau Schwabe
IC Layout Engineer
If you buy the "Starter" kit for $129.95 you get everything you need to get started (including the laminator).
Note that this system only does 0.032" boards and cannot do the "normal" 0.062" boards.
It's the easiest method I have tried. And I have made boards for the SX48 (0.5mm lead pitch) with success.
http://www.pulsar.gs/PCB/a_Pages/1_Menu/Overview.html
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
My next PCB project is going to be a surface mount project, but instead of using very small parts, I am going to use regular components, but bend all leads flat to solder on top of the board.· No thru holes, unless the component requires it, like terminal blocks.
Deno
Print on tracing paper and expose for about 10 minutes.· For 2 sides, print one side in reverse, and tape the two prints together so you can slide your board in between, like a sandwich.· Then sandwich between glass and use some weights like a sealed lead acid battery to press things together.· I print on an old HP laser jet, 300DPI.· Have successfully made boards down to 20 thou tracks and gaps, but found hand production too easy to get solder bridges.· So now I use min. 30 thou tracks and gaps, and set the copper planes up for 40 thou gaps.
It has taken a little time to perfect the process, but I have found that time was a very good investment.· In fact I recently invested in a bubble tank for etching, and now the whole process happens with minimal input from me.
bongo
Bean.
Mr Bean, thru plated is possible but is a lot of trouble. It is definately an improvement for industrial strenght boards, but somewhat meaningless on mine. For vias, I bend a bit of wire sharply so it cannot drop out when the solder melts as I am soldering the "other" side.
bongo
Really, I just made a 3"x3" pcb with mostly smd and .01 traces without a problem.· I have cooked at least 6 6"x9" sheets of pcb this way with only a few issues, mainly·when I was first getting setup.
Then I discovered expresspcb.com......have more $$ than time and don't bother with making the boards myself.
Ken
I don't usually get into specifics, am a lazy typer.· To expand a little though, my main problems with inkjet/transparancies where probably linked to the wrong product.· Just cause it says on the box "for inkjets........· But even with that resolved, laser is better, and transparancies are not stable at the temperature generated by the laser printers.· I found a big improvment in being able to align holes in large double boards using tracing paper.· It does not distort with the heat.
As for plated thu holes, my understanding is that they are more resistant to dry joint problems.· Which are themselves linked to heat stress which is not a problem I usually encounter.· They are also mechanically strong, which once again, is not a requirement for me, all my uses seem to be stationary.· If I was to be making an instrument that is destined to rattle around in a tool box, then I would see a need.
Would also suggest that you leave the photo resist on.· You can solder through it, it will protect the copper from corrosion in the short term.· For long term use, I brush clear estipol over the photoresist.· I tried a spray on solder thru laquer once, it worked well.· However it was expensive and I only got one use out of the can.· Then the nozzel blocked despite following all instructions on said can.
bongo
If you use this method I would reccomend preparing the copper surface with extra fine (000 grade) steel wool instead of the scotch-brite pad that the manufacturer reccomends.
Also, for big boards you might want to send it through by itself once to pre-heat it before the toner transfer step.
I have had good luck making boards with traces fine enough to solder an SX28SS.
Haven't had a need to try it on SX48 yet, but I think it would work fine.
I wonder if this wire is hot...
Heat generated in the finished product.· ie power trannies getting dry jointed.· Thru plating increases the soldered area whilst keeping the solder itself reasonably thin.
bongo
www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=81631
In combination with the XY translation table attachment, it really works wonders for drilling precise .02" holes
·1+1=10
We use an old carboard box with a UV light in it. We make transparencies on the laser printer and put that over presensitized boards with glass on top for 10 minutes. I'll check out the tracing paper idea next time. We also use small copper eyelets inserted into #60 holes for double sided. (you only have to eyelet the holes that go to traces on the top layer, not every hole.)
--Paul
Pulsar has white TRF foil to make the 'silkscreen' on the top of your PCB look "professional".
http://www.pulsar.gs/PCB/a_Pages/4_Products/5c_TRF_Foils/TRF_Foils.html
Post Edited (Paul) : 1/27/2006 5:15:00 PM GMT
