Sending commands to the Parallax Servo Controller (PSC)
Hello [noparse]:)[/noparse]
I've started a project with a µC that should controll a PSC. The µC is programmed in C/C++ and the commandoes are sendt on a serial tx line with the "sendByte" commando.
This is a sample of the code:
So, my question is simple really, will the psc understand this? I'ts especially the "!SC" part that concernes me... Everywhere else its sent as a string...
regards
Pengatom
1 + 1 = 10· |· 4 + 4 = 10· |· 5 + 5 = 10· |· 8 + 8 = 10
[b][color=#7f0055]void[/b][/color][color=#000000] update(unsigned-char channel, unsigned-char ramp, unsigned-short pulseWidth){[/color]
[color=#3f7d5f]//Code to send new position for servo to PSC
[/color][b][color=#7f0055] if[/b][/color](ready_to_send_new_message){ [color=#3f7d5f]//timer_int_handler() in interrupt_handling.c[/color]
ready_to_send_new_message = 0; [color=#3f7d5f]//1 msg every sec[/color]
msgbuffer[noparse][[/noparse]0] = [color=#2a00ff]'!'[/color]; [color=#3f7d5f]//Servo[/color]
msgbuffer[noparse][[/noparse]1] = [color=#2a00ff]'S'[/color]; [color=#3f7d5f]//controller[/color]
msgbuffer[noparse][[/noparse]2] = [color=#2a00ff]'C'[/color]; [color=#3f7d5f]//identifier[/color]
msgbuffer[noparse][[/noparse]3] = channel; [color=#3f7d5f]//Channel that the Servo is on (0-15)[/color]
msgbuffer[noparse][[/noparse]4] = ramp; [color=#3f7d5f]//Ramp Value (speed at which servo will attempt to reach new position)[/color]
msgbuffer[noparse][[/noparse]5] = pulseWidth; [color=#3f7d5f]//Value you want the servo to move to (250-1250,750=center)[/color]
msgbuffer[noparse][[/noparse]6] = pulseWidth>>8; [color=#3f7d5f]//Shifts all bites one byte to the right[/color]
msgbuffer[noparse][[/noparse]7] = 0x0D; [color=#3f7d5f]//End command[/color]
next_char = 0;
[b][color=#7f0055] if[/b][/color](next_char < 8){ [color=#3f7d5f]// Is the message sendt?[/color]
[color=#7f0055] [b]if[/b][/color](new_char_can_be_sendt){ [color=#3f7d5f]// Is the serialport ready for a new char?[/color]
new_char_can_be_sendt = 0; [color=#3f7d5f]// Sends msgbuffer[noparse][[/noparse]next_char] out to the PSC[/color]
XUartLite_SendByte(XPAR_PSC_BASEADDR,msgbuffer[noparse][[/noparse]next_char]);
next_char++;
regards
Pengatom
Jon Williams
No I'll just wait for the PSC to arrive in the mail so I can test it [noparse]:)[/noparse]
regards
Pengatom
Guess it something to do with ascii/not ascii format... I'll dig into this later today.
As I said, I'm sending one byte every second, but I don't know how fast I can send this to the PSC so it will understand it?
Regards
Pengatom
Edit: redused the pulswidth variable from 500 to 5, and now I'm getting the result that want. Seems like·the variable I'm using is probably not "big enough"...
Post Edited (Pengatom) : 1/25/2006 1:45:00 PM GMT
Jon Williams
My problem, or rather question, is about the psc.
What is the minimum time between each byte sendt to the psc?
Jon Williams
