PLC com via WIFI & GSM
I am new to the whole Basic stamp, and at 54 years old, I am just too busy to learn the whole thing.
I need a basic stamp program/device that will poll 2 ports [noparse][[/noparse]one on WIFI and the other on a rs-232 to GPRS device] to see which one is alive, then funnel communications from a PLC to that one.
Can you suggest someone to do this for me?
Duane Martin
[noparse][[/noparse]plc == programmable logic controller]
Duane Martin
also is the plc a master device that will poll your stamp for data? or does it have a dedicated listening port?
and how long are the sentences? the stamp can only handle so much, unless you use some external ram which will slow down the device ever more.
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
John R.
8 + 8 = 10
How did he send them all without filling up his PM mailbox?
The worst part is, the gentleman was really looking for help, and all he's getting is traffic on his botched attempt to get help.
Duane:
On the WIFI, do you have an actual device that has WIFI that you want the Stamp to communicate with, or are you thinking of the WIFI as part of the stamp system?
What you're asking to do isn't terrible in concept, but as they say, "the devil is in the details". Determining what format to get/send the data in could be the hard part.
If you're just looking to outsource this, including the design, you might want to make that clear also.
Reading your post, one is left with one of two choices for an initial impression:
Either you are trying to go from zero to full speed on a non-trivial application with no patience for a learning curve - "I am just too busy to learn the whole thing."
Or
You really are looking for someone to contact you, and provide a "turn key" solution for you - "Can you suggest someone to do this for me?"
There certainly are resources on this formum to do the second, and if you can find the time and energy, certainly the folks to help with the first.
John R.
8 + 8 = 10
Duane, please step up and tell me that ain't so.
Ray
Tim
kelvin
traceme.tv/io.html
