SHT11 Temperature Offset
Hello All,
I'm working with a SHT11 Sensor Module and a BS2P40 on the P40 Demo Board.· I'm reading a temperature from the SHT11, but it has an offset (high) of about 8-9 degF from the acutal room temperature.· I'm using my wife's digital meat thermometer·
to verify the actual temperature along with one of those digital clocks that show indoor temperature and they both agree that the SHT11 is high by 8-9 degF.
So my first guess was that the internal heater for the SHT11 is on, so I loaded the advanced SHT11 demo software·and executed the·Heater_Off subroutine in the "Initialize" section.··· This made no difference.
So does anybody have any ideas or seen this before?
John
John
http://www.emesystems.com/OL2sht1x.htm
Jon Williams
"Single chip sensor module, fully calibrated with digital 2-wire output. 0-100%, -40 to 120°C, fully immersible, accuracy +/- 3%RH, +/- 0.4°C @ 25°C, response time humidity sensor 4s"
http://www.sensirion.com/en/02_sensors/00_products.htm?cat=3&category=humidity%20sensors
Check the data sheets and see if they have a temp calibration curve chart....
Even those old mercury thermometers (and alcohol ones) have curves to them.
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
