C-cells and BOE-Bot
MacGeek117
How would I mount 4 C-cells instead of AAs on a BOE-Bot?
RoboGeek
There are·3 kinds of people in the world,
the dreamers, the do-ers, and the "Oh, what's this button do"-ers.
Formerly bugg.
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Chris Savage
Parallax Tech Support
csavage@parallax.com
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Using C cells is a good way because you can easily buy rechargible replacements and they really can add a lot.
In a pinch, you can get quite a bit more from Alkalines that from Nicads. So the 'C style' provides a flexible choice that other formats will not.
I have a litium 7.2cell [noparse][[/noparse]which can carry quite a lot of power and recharge quickly], but I bought an extra and overcharged it on my 3rd time.
Sadly, I wasted about $20USD for so little use. Litium also doesn't like a complete discharge. It is more optimal for electric airplanes where you really need to reduce the weight to power ratio.
Chris Savage
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Post Edited (RoboGeek) : 1/15/2006 3:31:01 AM GMT
Chris Savage
If you want to spend more, you could get a peak detection charger, and that way, you could charge all 5 cells at once (in series), but that's quite a bit of money just for not having to change batteries every few weeks.
C and D cells are better values as it really doesn't take much more to manufacture a C or D cell than a AA, but the capacity grows geometrically with the diameter.
Something about economies of scale.
I tried to figure out a way around the BasicStamp voltage regulator with NiCads and NiMH, but while four are 'rated at 4.8volts' that can easily go about 6 volts on a full charge. Also, the BasicStamp is programed with its Brownout circuit somewhere around 4.5volts. So you are struggling with too high causing damage and too low quickly shutting down.
About the only thing that can be done is to accept using the extra battery and go through the regulator. Still, you will easily get double the time or more from the Alkalines. The rechargilbes never last very long. They serve a different user.
You could add a 5.0 Volt low dropout Switching regulator to get 80-90% efficency rather than 70% efficency from the on-board regulator.
At some point it is really a question of how hard you can squeeze an orange? And why?
Using C or D batteries may be a good idea, since they will last much longer, but they are large (I cant imagine a boe bot with 4 D cells).
The only advantages to using rechargeable batteries are the higher current capacity (you can discharge rechargeables faster than you can discharge alkalines) and the fact that you can recharge them (probably saving money in the long run).
However, they will probably be more trouble, since you need to find a way to charge 5 or 1+4 at a time. Plus, when they run out, you have to actually recharge them.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
http://www.maxim-ic.com/PowerSupplies.cfm
Then you could make do with two AA, C or even D cells.
(It may be advisable to use NiCad or Ni-mh, though, as you'll be drawing more current from them)
Don't visit my new website...
Sounds good.
I am expecting Parallax to come up with a 'low voltage/low power' BasicStamp soon. One that runs on a 3.3volt regulator. Of course, the logic attached to it will have to adapt, but it will greatly stretch those battery powered applications whilst keeping the speed.
(Draws less power than when operating at 5V, too)
All it takes is to cut a single track...
No, I'm not saying which one as I don't want to be blamed when some clutz destroys his BS1/2...
Also, not all BS1's may be able to operate that that voltage.
Anyway, several Parallax employees have earlier thated that a low-voltage model is NOT being considered. First of all, the demand isn't very large, and second, none of the Appmods would work with it without some sort of interfacing. (Expensive)
There is a big savings in power without any drop off in speed by using 3.3volts as the regulated voltage. Not only is the current consumption less, the total power consumption is less. And, you have less problems with possilbe EMI from the high clocking speed. And, it runs cooler.
By the way,·someone offered me a Christmas present this year and I asked for a BS2 because it does only draw 2ma. For solar powered devices, it doesn't get much better.
I still have to check out that 4 pak for safety. It seems that D cells are a bit larger and top heavy, but the C cells are a good weight to power ratio without upseting the Bot.
Post Edited (Kramer) : 1/21/2006 5:09:16 PM GMT
