Encoder Help
TC
Has anyone had any luck hooking up a BS2 to an encoder? I am working on a project for the basic stamp to tell me what angle my table saw is set to. I have ordered an US Digital T5 Incremental Inclinometer “http://www.usdigital.com/products/t5 ”. It works on an optical encoder I got the 720 CPR model to give me a .5 Deg accuracy. (At least I think it will I will find out when I get it.)
Also do you think I would be able to use a BS1 instead of a BS2? There will only be the encoder, a MAX7219 to drive the LED display, and one push button to set 0 deg.
thanks
TC
thanks
TC
Chris Savage
Parallax Tech Support
csavage@parallax.com
I looked at the datasheet...
# Near real-time response
# Virtually free from linearity errors
...What's near real-time? ...and no virtual errors! I just had to chuckle.
Usually you don't see that as a highlighted point of interest in a datasheet.
...Anyway, the output looks to be straight forward quadrature output. My concern would be
if you moved the position of your table saw to quickly, that you would miss a count. I might be
missing something, but the output does seem to be relative. This means that you must keep
track of the position within the Stamp. If it were absolute, it would not matter, you just read
the position. For this reason, it might be wise to use a quadrature decoder chip in-between the
Stamp (BS1 or BS2) and your encoder.
Beau Schwabe
IC Layout Engineer
Thanks.
I bought it last night just waiting to receive it Would you have any recommendations that might work I googled and found nothing that will work with wire wrap?
I wish I had more knowledge about discreet components. Because I don’t think I need the BS for this. I just need to make a counter that will count from 0 to 500 (0.0 deg to 50.0 deg)
Also is there a good way for a beginner to test discreet components on the computer. I cat afford to buy parts and burn them up or get it so wrong that I would have to start over again.
The links below might be helpful... I have not used a single quadrature IC, but I have made one
with a few discrete IC's. ...Also, I have modified a standard PC mouse to work as a decoder.
Here you have the function of two quadrature decoders and at least two buttons with a standard
RS232 output.
www.fpga4fun.com/QuadratureDecoder.html
http://forums.parallax.com/showthread.php?p=519683
http://forums.parallax.com/showthread.php?p=515215
Beau Schwabe
IC Layout Engineer
http://www.usdigital.com/products/ls7083-ls7084/
It converts the encoder output to pulses that could be hooked to the BS2 easy.
· Cheers,
·Tom
·· I can tell you that·I have successfully used a·Grayhill Rotary Encoder in several projects with the BS2.· Now, if you spin the shaft really fast with your fingers, the BS2 misses pulses, but on a shaft encoder with a table saw I cannot see that happening unless you really drop the angle quick.· Rotary Encoders are rated also by the number of pulses per revolution.· The ones I use are 16, which is relatively low.· As the pulses go up, so does the timing required to read them.
Chris Savage
~ 3······ 74LS193········· DEC up/down counter w/ two clocks
~ 3······ 74LS247········· DEC to 7-segment driver
~ 1······ LS7183··········· Encoder to Counter Interface Chips (from US Digital)
See I am not looking for any bells. I just needed when I move the saw the display will tell me my angle and have a zero button.
So I would like to thank every one for trying to help me, and I could not find out about encoders with out all your help.
