Solderless breadboards vs protoboards and printed circuit boards
When I design a project it is usually on a solderless breadboard. However I have been working on a larger project with about 100 ICs and many wire cables. I currently have about half of it soldered on a protoboard. The problem is that the protoboard is starting to bend significantly (8.5 x 17") due to the weight of the IC's and more so on due to 8 wire output cables coming off of most every IC. The trouble I am seeing also is in troubleshooting all of the soldered wires (which may come off due to the heat from fixing an adjacent wire issue) to check every output cable and time spent cutting, tinning, and soldering every wire. I have decided on a new approach.
Is is "acceptable" as a long term project to have the project assembled on cascaded solderless breadboards (about 13-15)?
I have been working with solderless breadboards for years and didn't originally think this would be an acceptable format to use as an end format. The boards will be inside of a case at the end not exposed to public view unless future expansion is needed.
I also thought about having a PCB made up but it is much more expensive and harder to get one made on that big of a board.
Solderless breadboards allow for easy configuration and quick wiring (professionally look to keep wires short). Future expansion may also be needed to the design which makes this a good way to go too.
Comments?
Thanks.
Comments?
Thanks.
My personal preference is to migrate to PCB for the final product, as mentioned in your question about PCB design programs, you can daisy chain several different PCBs. Cadsoft's EaglePCB Lite (free) permits 3"x4" designs. If you switch to surface mount parts and dual side populate, you'd be amazed at how much you can squeeze onto a PCB.
To give you an example, the board Im presently working on has 12 QSOP24 chips (0.65 mm pitch), 192 current limiting resistors, 208 through-hole solder pads for offboard connection to LEDs, ~30 jumper resistors (0Ω surface mount resistors), 2 3-pin headers, power jack, board address setting pads and mounting holes and this is all squeezed onto a 1"x4" board.
·1+1=10
More of my projects depend on surface mount devices so I find myself building sub-boards that hold SMT devices or special critical functions like 900mhz transceivers. The sub-board holds the transceiver and its antenna. Only low frequency power and signals are run to the wirewrap board.
This approach can be useful when there remain questions about the proper functioning of sub-circuits. It can prevent difficult cutting of traces and soldering of temporary jumpers for testing purposes. However one must remember the current limits of wirewrap. I try to avoid passing more than 100ma through a #30 wirewrap wire.
I recently visited a website discussing the development of the Apple Mac computer back in the early 1980's. They wirewrapped the first five prototypes.
Post Edited (bobledoux) : 1/17/2006 2:31:53 PM GMT
Take a look at one of the subboards I made to convert them into DIP-like packets...
Thanos
I really like the usage of solderless breadboards vs the soldering hassle of soldering methods.
More comments welcome.
Thanks.
Can you break down your design into functional blocks? With a modular approach, it might be easier to manage. This way you
could also stack your protoboards so that they "plug" into one another. <--Wire wrap IC sockets are good for this.
Beau Schwabe
IC Layout Engineer
Thanks.
Comments?
Thanks.
kjennejohn
As a lead test engineer you ought already know that for a final product one NEVER uses a solderless board.
You used the word Professional in your first post. I can't think of anything less professional than a solderless board for a final product. If someone "Professional" tried to pass that off on me for a final product, I'd fire them on the spot!
So, there's my answer to your question.
Cheers,
Peter (pjv)
Thanks.
Below are the headers I usually·plug it on boards I constructing... (I couldn't find a better one right now to show you...)
Thanos
Flexible, yet nearly permanent.
If you make a mistake or want to redesign - you just unwrap the wire.
·1+1=10
·1+1=10
