SX-Key v 3.0 Bug?
I am using a Keyspan serial/USB adapter. it creates a COM Port 3 which I can select from SX-Key Config screen. However when I try to program I get Error Unable to Open Com2!!?! Anyone else run into this?
-Adam
-Adam
·· In the Advanced properties page of the KeySpan VCP Driver (From your device manager, ports) you should be able to disable the FIFO buffers on the adapter.· This is often a problem on laptop computers.· BTW, version 3.1 of the SX-Key Editor is available on our website.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Did the above suggestion work????
Please let us know. It is good for future reference and for every one's knowledge base.
Sam
