Serout a variable or pin state
Hello,
· I have searched the forum many times and have·seen example code to serout a variable or pin state.· I tried using the programs john has provided and hitt consulting.· It always send the hex format (Or not the actual number) or·variable I try to send.· For example
DEVICE SX28, OSCHS3, TURBO, STACKX, OPTIONX
FREQ 50_000_000
InPin VAR RB.0 ' Change this to whatever pin you want to monitor
SOutPin VAR RB.1 ' Change this to whatever pin you want serial output from
Temp VAR BYTE
PROGRAM Start
Start:
· INPUT InPin
Again:
· Temp=InPin
· SEROUT SOutPin, N115200, Temp
GOTO Again
This should send a either a 1 or a·0 out.· However I get a smiley face or some other character.· I have changed the baud rate even to 2400 it does the same.··It wont send any characters unless I·switch to N2400 instead or T2400.· The hardware connection I have it a serial plug with the serout pin connected to it and hyperterminial connected.· It is also grounded to the·ground.· The pin I am using on the serial cable in number 2 for the connection and number 5 for the ground.· I can send·one letter at a time using·this format:
Serout Ra.0,·N2400, "A"
But I need to send the pin state·and a variable seperatly
Serout Ra.0, N2400, Variable
I am using an external osc like you said and I tried·all different freq and resinators.· Can you please help I am·semi new to this chip.· ·
In Short It must always be in "" for numbers to be sent or words.· Which I need to send variable data.·
Thanks again!
Tony
FREQ 50_000_000
Temp VAR BYTE
PROGRAM Start
Start:
· INPUT InPin
Again:
· Temp=InPin
GOTO Again
Thanks again!
Tony
· Welcome to the forums...
· Change Temp=InPin to Temp=InPin+"0"
· There is a difference between the value 0(zero) and the character 0(zero). It happens that the character 0(zero) has a value of 48, and the character "1" has a value of 49.
· So you have to add the value of the character 0(zero) to your bit value.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
Post Edited (Bean (Hitt Consulting)) : 1/13/2006 2:16:31 AM GMT
First of all thank you soooo much beacuse the above code now works.· However I have another problem, This program I created, which I will list below sends each pin state seperatly, I need to have the four pin states that I choose sent at once.· I found another program you wrote earlier that goes like this, but it does not work.· It sends nothing.·
DEVICE SX28, OSCXT2, TURBO, STACKX, OPTIONX
FREQ 4_000_000
inport var RC
soutpin var RB.0
Program Start
Start:
Serout soutpin, n2400,inport
goto start
I can go the route of all pins being sent at once but I can not get the program working.· My program goes like this:
FREQ 4_000_000
InPin3 VAR Ra.3 ' Change this to whatever pin you want to monitor
inpin2 var ra.2
InPin1 VAR Rc.7 ' Change this to whatever pin you want to monitor
inpin0 var rc.6
SOutPin VAR Ra.0 ' Change this to whatever pin you want serial output from
pins2 var byte
pins3 VAR BYTE
pins1 var byte
pins0 var byte
pinto var byte
PROGRAM Start
Start:
· INPUT InPin3
· input inpin2
· input inpin1
· input inpin0
· plp_A.3
· Plp_A.2
· plp_c.7
· plp_c.6
Again:
· pins3=InPin3+"0"
· pins2=inpin2+"0"
· pins1=inpin1+"0"
· pins0=inpin0+"0"
· SEROUT SOutPin, n2400, pins3
· Serout soutpin,n2400, pins2
· SEROUT SOutPin, n2400, pins1
· Serout soutpin,n2400, pins0
·GOTO Again
In Short I need it to send 1100 then send
instead of 1 send
·············· 1 send
All Pin states need to come at once.
You are the man so any suggestions?
Tony Castrovinci
Jon Williams
Thanks again,
Tony Castrovinci
Jon Williams
