Fast transistor at high current
Hi Guys,
My problem is simple, i need a transistor or darlington or FET or whatever does the job to get a positive current of 1.8A 5v on and off in less than 100-300 nanoseconds =S hehe is it possible?????
Thanks a lot.....
···················· ............Javier
Thanks a lot.....
The problems with BJTs are heat. With Darlingtons, you have more gain and even more heat.
I think it is possible and you may even get a FET taylored to direct input from TTL to do the job, but the device may have to be between the FET and the grounded side. This implies that you would not be able to use a voltage higher than the output of the TTL [noparse][[/noparse]I assume a Stamp] and it might drop a bit -- to 4.4volts.
FETs seem to be available for 10amps and more. They even have 'flyback' diode protection in some.
·1+1=10
"The Only Thing Im Sure Of Is That Im Never Sure Of Anything"........
Post Edited (Scarecrow) : 1/12/2006 8:38:10 PM GMT
·1+1=10
·1+1=10
